Question about Toshiba P845t-S4310 Laptop i5 1.7GHz 6GB 750GB DVDRW
Disable touch screen
The touch screen has creak by an accident and i would like to turn off the touch so that i can use it
HOw do I turn off touch screen on a Sony VAIO Tap 20 Touchscreen All-in-One Desktop Computer, Intel Dual-Core i5-2430M 2.4GHz, 8GB RAM, 750GB 5400 RPM HDD, Windows 7 Home Premium 64-bit
1.Press the Windows logo key + X.
2.Select Device Manager from the list.
3.Click the little arrow next to Human Interface Devices to expand the list.
4.Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
5.Right-click, and select Disable from the list.
6.Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
7.Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
See the website
Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO VPCL23CFX/B All-In-One PC - 2nd...
How do i turn off a my sony all in one touch screen, i do not touch the screen for options, and its driving me crazy
  1. Press the Windows logo key + X.
  2. Select Device Manager from the list.
  3. Click the little arrow next to Human Interface Devices to expand the list.
  4. Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
  5. Right-click, and select Disable from the list.
  6. Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
  7. Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable See the website
S
SeS Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO Tap 20" Touchscreen All-in-One...
Q302lamy asus touch scree not working model number
Go to the search bar, type device manager it will be listed under control panel. The touch screen may have been disabled by accident or maybe a driver malfunctioned. under Human Interface Devices it will be one of those, right click on them and see if any say enable go ahead and click enable. If none are disabled try clicking "update driver software" it will be located under the same menu as the disable/ enable feature. i will attach two pictures of what it looks like. Now if neither of these works i would say it's a faulty touch screen.
25143119-o3dodzl4qyaya15qun0b2bn0-2-0.jpg 25143119-o3dodzl4qyaya15qun0b2bn0-2-1.png
Sep 26, 2014 | ASUS 13.3" Touch-Screen Laptop - 4GB...
2nd generation 8gb .. ipod touch, is disabled/connect to i tunes (pin LOCK CODE)
1. Keep the power and home buttons pressed until the "Connect to iTunes" screen comes and restore (everything will be erased).
or
2. Ssh your iphonego to th path mobile/Library/Preferences/delete com.apple.springboard.plistoff and on your iPhone (MAY need to be jailbroken, not entirely sure).
Apr 01, 2012 | Apple iPod touch Second Gen (8 GB,...
The two buttons on touch pad do not respond, can they be removed for cleaning like a keyboard or haveI disabled them accidently
The buttons on the touchpad are an intergal part of the palrest and cannot be taken out.
Boot the laptop up into the BIOS by pressing F2 when the Dell screen appears.
Not being sure what BIOS rev you have all I can advise is to look through the BIOS and insure that they haven't been disabled.
Jan 07, 2011 | Dell F3534 Touchpad
I have an hp tx1000 and my touch screen is not responding at all
Hmmm... touchscreens can be complicated in ruling out what is excatly causing the root of the malfunction. First check to see if you turned the touchscreen option off. There could be a FN button that disable the touch screen and maybe you accidently disable it. I used to have a tx1000 too, but sold it because of the common heating promblem of these machines that cause future malfuctions, only if I sitll have it, I'd be more clear about it. However if that doesn't work, then it could be a driver promblem. Did you change the operation system?, deleted programs associate to the touchscreen? or updated a newer version of the drivers? If this is it, then common promblem could be associated with the drivers of the touchscreen, you will have to reload the driver agian, and can be found in the Hp drivers support section. Other then that, if promblem has not been fixed, then a cablewiring in the laptop somewhere that connected with your screen has become discconnected and loose, because surely those hp tx does do so twisting and turnings which your going to have to take the laptop apart.
Dec 08, 2010 | HP Pavilion tx1000z Notebook
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
My cursor on my toshiba laptop keeps jumping when am typing
Ive seen this problem a few times, the problem is that your accidently or inadvertently touching the touch pad as you type. To fix this just disable the touchpad when your typing or put a piece of paper over it. To disable the touchpad it varies on different models but can normaly be done with a button near it, a FN and F1-8 key combo or through the touchpad driver on the task bar. Consult your manual for information on how to disable this.
May 08, 2009 | Toshiba Satellite A205-S4617 Notebook
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Toshiba P845t-S4310 Laptop i5 1.7GHz 6GB 750GB DVDRW Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
