Hi i got a schwinn 825 and it stops working within seconds and shows error E6. What am i supposed to do to fix it? Can anyone please assist, thank you
SOURCE: schwinn s180 wont charge
hi, just plugg it in turn it on. there should be a red and green light on your charger.
SOURCE: The console does not work. E-2 shows up on the console.
We had this problem after assembly as well, it turned out to be a bent pin inside the connector to the flywheel housing (where the wires connect inside the lower part of the main mast). It was so bent that it never actually made contact with the connector.
We straightened the pin, carefully reconnected the wires, and everything worked just fine.
This says to us that the "E-2" error message means the console is missing at least one connection from the system. This could be caused by a bent pin, a torn/cut/frayed wire, etc -- anything that might make it lose signal.
So check the lower connection for bent pins, check the upper connection for bent pins, and check all along the wires for any kind of damage.
Hope this helps!
SOURCE: treadmill shuts off in about 60 seconds.
try calling the techinal number tell them the problem and they should be able to help u
SOURCE: We bought a Schwinn 12
Just found the 10x2 tubes here. I am going to order today. I will let you know if I have any problems getting them from this supplier.
http://www.racemotorparts.com/products.php?id=1329
SOURCE: error code 1 on schwinn elliptical 418
E1 error seems to indicate that the servo which controls the elliptical resistance is stuck. Here is how I fixed this (without using a "crank puller", which would be quicker by far).
You will need a very short phillips screw driver (snub nose), a long phillips screw driver, an allen key set, and crescent wrench.
- Remove the batteries from the unit.
- Remove the screws from the plastic housing (with the long phillips screw driver) on the left side. Do not forget the phillips screws at the front - they are smaller screws so don't mix them with the others. This will allow the plastic housing to flex and move around, but not come entirely off.
- Using the crescent wrench, remove the nut holding the left pedal to the crank. Carefully note the order of the washers on the crank attachment.
- Using the allen key, remove the little pedal attachment piece on the left crank arm.
- Using the short phillips screw driver, carefully reach inside the plastic housing on the top and remove the four screws holding the plastic plate on the outside of the fly wheel/crank. You will need to rotate the crank wheel to reach each of the four screws in turn on the inside of the case.
- Pull off the plastic cover for the wheel.
- Reinsert batteries and gently help the revealed cable (bottom) retract the magnet plate. In my case, the servo worked fine again after helping it retract the magnet plate that was somehow stuck/wedged.
Reverse steps to re-assemble.
