Question about Panasonic Microwave Ovens
Panasonic Pro 11 Microwave
We have an old microwave but works perfectly recently the timer control was turned and it came off its bracket and snapped the wires. We ordered a replacement which arrived and note inside said this may look a little different to original but it will be okay.The problem we have is the colors on old appliance were 1 x White. 1 x Black and 1 x Brown. This new switch as 3 wires also but are 1 x Orange 1 x White and 1 x Yellow does anyone know which wire we need to make off to corresponding wires
MicrowaveSvc
  • 9098 Answers
SOURCE: PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing.
Posted on Aug 12, 2008
mumma_1
  • 903 Answers
SOURCE: Yam caught fire in microwave
If you have given the microwave enough time to cool off and it still does not work then I would suggest that you would need a new one, as the circuit board may be fried that connects the control panel.
Posted on Jan 15, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Wiring Diagram for Microwave Door Switches
It took me a while, but I was finally able to get the FULL service manual that covers these models:
NN-S252BF
NN-S252WF
NN-S262BF
NN-S262SF
NN-S262WF
The wiring of the door interlock switches is shown on page 10.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Feb 05, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave - fans & turntable not working
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Feb 15, 2009
  • 52 Answers
SOURCE: NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Posted on Feb 21, 2009
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How to change a fuse in a GE Spacemaker XL Microwave
  • 1 Remove the old fuse from the compartment that the control panel was covering by grasping it and pulling it out. Place a new fuse in the compartment and push it firmly into the holder until it snaps into place. Connect the wires to the control panel according to the labels.
  • 2 Place the control panel on the microwave and install the retaining screw with the Phillips screwdriver. Install the grill on the microwave and snap it into place. If your microwave grill has retaining screws, install those and tighten them using a Phillips screwdriver. Plug the power cord in for the microwave or turn the power on at the breaker box and program the microwave according to manufacturer instructions
  • home light bulbs
    May 03, 2012 | GE Microwave Ovens
    Microwes panasonic nn-t553w
    hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
    Mar 06, 2009 | Panasonic NN-S753 Microwave Oven
    GE Blt In Microwave runs but NO SOUND and shows NO SOUND on control panel
    Hello Marlenes,
    A 1996 microwave that is still operating at all is the exception rather than the rule..It is possible to resolve the beeper problem but the costs associated with it probably aren't worth it. To get >11 years use from a microwave without major component failure is great.. I would just live with it.... (Your call)
    Regards
    Oct 11, 2008 | GE Microwave Ovens
    How do I take it off demo
    timer button 4 time on demo mode
    time button 4 taps more off demo mode
    see page 11 of your manual
    please rate me for this
    Jun 23, 2008 | Panasonic NN-SD997S Microwave Oven
    Microwave not heating unless exhaust fan is on high
    check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
    Sep 26, 2007 | Samsung MW1030WA Microwave Oven
    The microwave does not work.
    check control circuit and related control panel circuit
    Jul 28, 2007 | Panasonic NN-T993SF Microwave Oven
    Microwave Ovens Logo
    19 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
