Question about JVC KD-S5050 CD Player
Keeps jumping betwen cd and radio - JVC KD-S5050 CD Player
Kenwood KDC-MP342U turns on but just keeps saying "reading" when in usb mode. I recently had it go into protect mode and I took the stereo out and checked the wires and re-attached the ones that...
it sounds like the USB connector on the face place of the radio has a cracked solder joint. i suggest taking it to a person that know how to solder small objects. your Kenwood has a one year manufacturer warranty it could be some thing to check in to.
Jun 18, 2011 | Car Audio & Video
It jumps from function to function by itself and won't stay on the one I want. For example at the moment I want it on the Aux function, after I choose it it will jump to CD, then FM radio and keep jumping...
hello conorknot!
seems like it is in demo mode? did you check users manual for some info? since you didnt wrote model and brand i cant help you that much...
regards
Feb 20, 2011 | Audio Players & Recorders
My LG TV is menu jumping by itself it keeps switching between 3 different screens. What is causing this? Thanks
Issue with Sticky Button Due To Humidity and dust acumulation betwen contact Solution Take Off You Pad Selector and Clean-it
To do,,,So You must take Off our Back Cover and Rich inside your Front Panel and Take Off the Board then take off the Rubber Pad and clean it.. with a Q-tip warm Water dont use anything beside water like acetone or Alcool you will damage it..
Sep 22, 2010 | LG 47LD450 47 in. TV
Hello. I have a panasonic sa-ak45 and drive left open, what happens is that when you press the button open / close it just displays the message "changing" and never goes out of disk 1. It will be a...
The disk jumped from the internat platform , you must open the back case and push the CD a little. He is stucked somewhere betwen. It's very easy . just 12 screws
Sep 02, 2010 | Panasonic SCAK410 5-Disc CD Changer
My car battery died, after giving the car a jump, the car started, but now my pioneer DEH-P2900MP car stereo won't work at all. could you please assist. thanks.
If you have already checked the fuse(s) that supply the radio and none are blown, you may want to try to reset the unit by disconnecting the power feed to it. Keep in mind that the radio likely has two power feeds...one for the ignition and another that keeps all memory functions up and running, even when the ignition is off. Disconnecting both of these may allow the radio to reset.
Feb 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
My battery recently died in my 2007 focus hatch and after jumping it off the car would start however the radio/cd player would not turn on. I thought nothing of it until i replaced the battery and the...
My radio can be on even without the key in (01 focus) maybe the radio is directly wired to the battery cable and your wire has been fried or damaged from the 'jumping'. You may want to carefully inspect the little wires attached to your actual battery connectors.
That's my guess.
Aug 08, 2009 | Ford Focus Cars & Trucks
Drained battery
you may have damaged the battery and may need a new 1 and also check the wireing on the dash board as the perminant live which is the yellow wire could be connected to the live which is the red wire on the radio which keeps the radio on even if the keys are out the ignition
Jul 05, 2009 | Panasonic CQ-C7301U CD Player
Sony ICF-C212 Clock Time Problem
that clock use LM8560 IC. if u live in a country with 50hz, u must close the jw11 (this make a jump betwen those pins 15 and 26). that enable the 50hz. left it open, when is 60hz.
Mar 21, 2008 | Sony ICF-C212 Clock Radio
JVC KD-S5050 CD Player Logo
19 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
