Question about Zephyr Venezia ZVE-E30 Kitchen Hood
The display panel has blinking square lower left corner and no longer works
The fan was shut off and the display panel now has a blinking small square in the lower left corner of the display. None of the controls work except you can turn the air recyle on and off. The lights do not work and the fan does nmot work.
Electrolux fridge temperature control displays a "square"
Try lower either the thermostat setting or the airflow control to the refrigerator to see if the temps are lowered.
Nov 26, 2013 | Electrolux Frigidaire Fridge Defrost Timer...
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
I turn on the calculator and all I get is a small black square dot in the upper left corner. TO Connect can read the unit, but nothing works on the display.
If the small black square does not blink The Calculator is Locked
it need an hardware reset
let me know if you if you want to fix the Calculator
ecrdn@yahoo.com
Jack
Oct 21, 2010 | Texas Instruments TI-84 Plus Calculator
Pld2560lcc1 Dishwasher...Control Panel shows 65 minutes left on lower rack, works for about 1 minute, shuts down. None of the buttons work. I changed the control (major circuit) board, same problem. I...
pulled the touch pad, go after the middle third with a very small screw driver, cleaned the flex circut with contact cleaner
powered up fine seems to be working again
Jan 23, 2010 | Frigidaire 24 in. PLD2560LCC Energy...
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
Dish washer doesn't drain, and control board only blinks
sounds like the control board is faulty. i would suggest having a technician replace it.
Sep 13, 2008 | Dishwashers
Zephyr Venezia ZVE-E30 Kitchen Hood Logo
90 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
