Question about Mitel 5220 IP Phone
Mute handset How do i mute the 5220 whilst on a call?
Can I delete the mute facility
sorry that is not a option you can do .
Mar 14, 2016 | BT 4500 Cordless Phone - DECT - Satin...
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
When switch on my cell then error comes contact service and after that cell is switched off. Cell Model No. Nokia Xpress Music 5220.
With that error message, your Cellphone needs to be serviced. Because with that error, there is something wrong with the program of your handset and it needs to be serviced. Don't worry, A local cellphone technician can manage to fix that problem. It just a software issue of your handset.
Cheers!
Jul 04, 2011 | Nokia 5220 XpressMusic Cellular Phone
Hi..I am using Nokia 5220 music Express...1 month ago my handset got blank...I was asked to have flash..so i did..Now its again got blank...when i switch on my handset white screen appears for sometime...
it problem with your rom memory which don't hold firmware.again flash it and sell it.
or second option is got it to nokia repairing shop to repair itsmain memory.
Apr 21, 2011 | Nokia 5220 XpressMusic Cellular Phone
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Dec 13, 2010 | Mitel 5220 IP Phone
Have bought BT Verve 450. Am looking for the MUTE
Hi, If you press the button phone book button - Looks like a book symbol.
Whilst in a call the handset will show "Mute On" press the button again to unmute.
Hope that helps.
For the BT Verve 450
Ryan - Worldhosted
Sep 15, 2009 | Uniden Cordless Phone
Nokia 5220 what is restriction code IMEI 355746020234125
Restriction code is the code that, u must get from your cell phone operator in oreder to unlock the phone....
This code operator specific and not phone specific...If your Handset is set to special agreement with the operator,then they may lock and they give u restirction code after the agreemetn termination
After agreement termination ask your operator for the restriction code
EnJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 28, 2009 | Nokia 5220 XpressMusic Cellular Phone
Mitel 5220 Electronic hook Switch?
The only electronic hook switch that I know about is on the 5330/5340 series phones, with the cordless headset from Mitel.
Here is a link to see what they look like... I have several installed at sites and the customers love them, no more handset lifters are involved. http://www.mitel.com/DocController?documentId=25305
Jul 24, 2009 | Mitel 5220 IP Phone
My nokia 5220 Security code Reset !!!
hai,
You go and visit the site, where you bought the code.And login to the site.you will get the details.
otherwise, you will use this .It's having http://www.mobile-unlocker.com/nokia-5220-xpressmusic/rs2wp9/ unlocking code and instructions for your mobile at low cost.
May 08, 2009 | Nokia 5220 XpressMusic Cellular Phone
Mitel 5220 IP Phone Logo
41 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
