Question about Panasonic TH-42PV80 Plasma TV
Where do i source a Power supply Mod. model LSJB 1260-1
Power supply faulty.
Hello sir I have canon ir 3300 in this code error is 000001-0002 so how can I solve this error
http://printcopy.info/?l=en&mod=erc&brand=canon&model=ir3300&code=E001-0002
Quoting from internet link:
Exploded Views and Parts List Free!
Code
E001-0002
Description
The sub thermistor detects about 295C or higher
Causes
The fixing film unit is faulty (i.e., the thermistor has a short circuit). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service move: COPIER>FUNCTION>CLEAR>ERR.
Remedy
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 W (short circuit)? YES: The thermistor has a short circuit. Replace the fixing film unit. If the thermistor has a short circuit, the indication in service mode (COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC= 250°C for the main thermistor; FIX-E=310°C for the sub thermistor. 2. Main power supply PCB, DC controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Canon iR3300 Error Codes
May 01, 2018 | Canon Office Equipment & Supplies
Error 010 on canon ir 2016
E010-0000 Main motor failure
The main motor is faulty. - Check the connector of the main motor.
- Replace the main motor.
- Replace the DC controller PCB. http://mfpdoc.com/?mod=free&chap=erc&brand=Canon&model=iR2016
Feb 18, 2017 | Canon imageRUNNER 2016 All-In-One Laser...
Ir 6570 error code e0004 e00103
E004-0103 The IH power supply is faulty/the IH control mechanism is faulty. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
The IH current is faulty. (no current) - Check the connector for any fault in connection. - Replace the fixing heater power supply. - Replace the DC controller PCB.
This link also offers a down loadable pdf service manual.http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR6570
Apr 15, 2015 | Office Equipment & Supplies
Lcd tv turn off while running condition but red ligt is still on
FAULTY POWER SUPPLY DUE BAD OR BULGED CAPACITORS
UNDO THE BACK I INSPECT THE POWER SUPPLY
THE POWER SUPPLY LOOKS LIKE THIS :
: http://pictures.kyozou.com/pictures/_12/11729/11728602.jpg
REPLACE THE BULGED CAPACITORS, MAKE SURE THAT REPLACE FOR THE SAME ONES.
IF NOT WORK, REPLACE THE ENTIRE BOARD (google it for u)
https://www.google.com/search?sugexp=chrome,mod=19&sourceid=chrome&ie=UTF-8&q=JVC+LCA90796+LT-42X579+POWER+SUPPLY
HOPE 2 HELP
www.bostonrecycling.net
Jun 30, 2012 | JVC LT-42X579 42 in. LCD TV
Sony Bravia KLV-32S310A model - Problem is Power supply okay but no sound & no picture. What can be the problkem?
If the power supply was given a clean bill of health by a reaputable source, then most likely a faulty mainboard
Sep 21, 2011 | Sony Televison & Video
What is with the constant buzzing noise?!
That buzzing noise is the power supply. You probably have a bad capacitor somewhere on the power supply. You can find and replace the cap or change out the power supply. Herre is a link to one at TvPartsGuy.com http://www.tvpartsguy.com/servlet/the-1260/LG-42LB4D-POWER-SUPPLY/Detail
May 10, 2011 | LG 42LB4D 42 in. LCD HDTV
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without it...you have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
Why does my panasonic radio say F61 when i turn it on
Possibly a faulty audio power amp or power supply integrated circuit, a faulty fan perhaps.
A power source problem. Means there is probably voltage measured at the output/speaker connectors. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the ac power source from the wall is wired correctly and has proper voltage and grounding.
Apr 10, 2010 | Audio Players & Recorders
Sony vaio mod. PCG-7T1L will not turn on. power supply ok.
Have power supply checked with digital multi meter as they can still be faulty with green light on.
Mar 16, 2010 | Sony VAIO VGN-N320E Notebook
I;ve just boughta Epson scanner mod 1260.used.no operater instructions.Q.how to use? Alec.
No Worries, its very easy to get started.
You will get lot of info on how to get started is available on epson website itself, you just need to know your scanner model and you will get all the required info.
Please follow the below URL to read and download all HOW TO.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14553&prodoid=21643923
Sep 30, 2009 | Office Equipment & Supplies
Panasonic TH-42PV80 Plasma TV Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
