Question about GE Monogram ZDI15C Automatic Icemaker
Ice maker goes to cleaning cycle only
Ice maker sat for about 3 months. I reinstalled then turned on and ice maker went into cleaning mode. it runs through cycle and then turns off
catriver
  • 878 Answers
SOURCE: GE PSS26 NGP Ice maker
Hi Vadim, You should have a steady light showing on the ice maker. If the lead is flashing, it's either a thermistor failure or ejector not home. The reasons why the ejector blades will not home is because of a magnet failure, control board failure or a stalled motor. The feeler arm could also be sticking. The control board contains 2 sensors that are activated by magnets. One magnet is attached to the end of the ejector arm to determine whether the ejector blades are at home. The other is located on the ice sensing arm, lets the control know whether the arm has reached a fully extended position. In a lot of these, I find the magnets broken. I think you can save yourself a lot of trouble by just replacing this ice-maker. Catriver.
Posted on Dec 29, 2007
emissionwiz
  • 80637 Answers
SOURCE: ge self cleaning oven wont shut off
replace the oven control circuit board.
Posted on Jun 21, 2009
  • 464 Answers
SOURCE: ice maker makes ice really slowly
perhaps there is not enough water being brought to the ice maker from the inlet valve. you may have to change the valve.
Posted on Oct 24, 2009
  • 1891 Answers
SOURCE: The ice maker stops making ice, and the freezer
you may have a p c board failure . it has not completely it will . the board gets stuck in defrost and you have a melt down . ( main board d wr49x10152 ) / if not the board ck when it hapens the evap fan in back of freezer .. .. also ck for frost in back of freezer .. mm
Posted on Dec 17, 2009
Testimonial: "Suspicions confirmed. Further investigation revealed motherboard recall starting May'05. We bought in Sep'05. GE's website is silent on the issue."
  • 153 Answers
SOURCE: ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Posted on Feb 08, 2010
Icemaker will not restart
1 Lower the bail wire to turn on the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Apr 10, 2015 | Refrigerators
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Installed new valve, getting water to valve but ice maker will not cycle or call for water
GE's ice makers are harvestable, means you can manually tell the ice maker to harvest or cycle. Turn ice maker off, went 5 seconds, turn ice maker back on, tap the paddle 3 times (push the paddle inward completely) then it should cycle, may have a delay like 20 second. I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 12, 2011 | GE WR57X10033 GE Refrigerator Water Valve
My scotman model sce170a1a.goes into harvest to
That has to be a faulty control wouldn't you think?
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice maker not dropping ice, the switch is on, and the ice has been in the tray for quite some time now
POWER ON DIAGNOSTICS TEST MODE When the ice maker is first connected to power and the thermistor temperature is 50°F or more, the control will initiate a “Power On” test before entering the freeze cycle. The test will consist of the following sequence:
1)Turn on the motor until it reaches home position
2)Turn on the water valve for 1/2 second
3)Turn on the heater for 1/2 second
4)Verify that the feeler arm was in the “in” and then the “out” position.
5)Verify that the motor was not in the home position and then in the home position.
6)Verify that the motor does not remain on after being turned off.
7)Proceed to the freeze cycle. SERVICE DIAGNOSTICS TEST MODE During the first 15 seconds that power is first applied to the ice maker, the Service Diagnostics Test mode may be entered. The Service Mode is entered by pushing the feeler arm in and out three times within 15 seconds. (only three times). There will be only one fill cycle (5.1 second) in the service diagnostics mode without the waiting period for the mold to “pre-chill”. If the ice maker has already started a harvest cycle and the arm is moving, it may be impossible to start the service mode. (since the NORMAL cycle is already started). While in the “Power On Diagnostics” test mode, the “Service Diagnostic” test mode can be initiated and will override the “Power On Diagnostics” test mode. This ice maker has no replacement parts available and is not intended to be repaired.
Jan 26, 2010 | Refrigerators
Amana scd25tl icemaker doesnt dump properly then runsover alot when refilling. The water doesnt shut off for more than a minute
if all the ice cubes do not come out of the tray every time / then when next water cycle turn's on it has to over fill. it is a measured amount . so look to see if tray coating is failing / if black it probably is bad . newer one's are tan/ buff colored . . hope this helped mm . to correct replace the ice mker .
Dec 19, 2009 | Refrigerators
Starts to make ice, but goies in reverse cycle before finish
OK. Forget the board. what you hear is the pump running when the unit is off. It sounds like a drain is kinked and the pump is shutting it down for safety.Also when this unit starts it will dump early for a couple of cycles before the ice gets normal size. Run the icemaker and unplug the pump in your water trough to make sure it has a frost pattern all the way thru.(takes 5 min)If not it could be a leak it the sealed system. Remember when you adjust the setting on the board this will take 5 cycles before you see any changes. And 24 hours for more consistant ice.
Mar 26, 2009 | U-Line Icemaker
Ice maker will fill when there is still Ice in the tray
adjust the screw in the front of the ice maker under the plastic face pull on that there is a screw in there turn the screw till it is almost in and it should limt the problem
Dec 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
GE Monogram ZDI15C Automatic Icemaker Logo
24 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
