Question about Adafruit MakerBot Edition
Need diagram of makerbot mightyboard - Adafruit MakerBot Edition
Any idea about 3d printers parts suppliers?
It would more better to answer if you add your shop location. Whatever, you can contact with a good supplier who can provide you all the parts easily to you.Before ordering you should ask the supplier about sending time,price for bulk and and warranty,because its help you to support your shop customers. i know a 3D Printer parts supplier ,you should try,they are supply through amazon.
May 04, 2016 | MakerBot Replicator 2 Desktop 3D Printer
Where can I get a wiring diagram?
NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS ...
www.faqqq.com/.../need-wiring-diagrams-for-lionel-1055-texas-lionel-doll...
Question Product: Lionel Dolls, Playsets & Toy Figures Question Details: NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS NEED WIRING DIAGRAMS ...
treadmill wiring diagram Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > treadmill wiring diagram
Ask your treadmill wiring diagram doll, playset and toy figure questions. ... need a wiring diagram for a massey ferguson 135 tractor lookin for a complete wirng ...
pactrol p16 wiring diagram Dolls, Playsets & Toy Figures ..
Jan 17, 2016 | Toys
Need mightyboard motherboard
Here is a link to buy a replacement motherboard, in case you haven't already purchased one. It is from the manufacturer. You can get it with or without the power supply. MightyBoard Power supply
As for installation, here is a handy youtube video that explains the installation process of the makerbot mightyboard. Replacing the MakerBot Replicator Mightyboard
I hope these links help you with your 3D printer!! Best of luck!
Feb 07, 2014 | MakerBot Replicator 2 Desktop 3D Printer
Need diagram motherboard
The manufacturer's website should have the manuals for this motherboard which usually contain a diagram of the board. If you need a diagram of all the circuits on the board you may need to email MSI directly for it. Detailed diagrams are usually for repair services only and are not readily available to the consumer. Good luck.
Nov 30, 2013 | MSI Computers & Internet
Clogged Extruder head
It is not unusual for the extruder to get clogged, especially when changing filament. the problem occurs when pulling the hot filament out and a tail forms within the filament channel. you can remove the stepper motor and try and pull the filament out. also unscrew the extruder tip and see if it will pull the clog out with it.
I use boiling water to clear the extruder head and it works nicely. if it is stuck in the filament tube you may need to pull the filament tube also to clear it out. it is also possible to remove the stepper motor and heat the extruder on preheat and push the tail inside the tube.
once this is done you should be able to "Load Filament" normally and once the new color id extruding your good to go.
May 13, 2013 | MakerBot Replicator 2 Desktop 3D Printer
Wall-e u comand robot, will not move forward he just turns, can i fix the right wheel?
On the in side of the body (cube) is a white gear the size of a 50cent coin. It is pressed on a drive shaft. The inter ring is cracked and slipping. It makes Wall E turn around and around. I'm looking for a replacement or some one with a makerbot to reproduce it. If any one finds one let me know at. stevepiper@usa.com
Apr 19, 2012 | Disney Wall-E U-Command Remote Control...
Need a wiring diagram for both these pickup(not audio)
what part of wiring diagram ? and i might be able to email it to ya
May 07, 2009 | Dodge Pickup Cars & Trucks
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Adafruit MakerBot Edition Logo
70 people viewed this question
Top Adafruit Games Experts
Camryn Johnson
Camryn Johnson
Level 1 Expert
Pamela Leach
Pamela Leach
Are you an Adafruit Game Expert? Answer questions, earn points and help others
