Question about Sole Fitness Sole E55 Elliptical
Control board states that it needs lube.
Sole e 55 elliptical control board states that it needs lube
Sole elliptical e55 makes thumping noise
If you wish to get some details about elliptical and treadmill ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 28, 2016 | Sole Fitness Sole E55 Elliptical
Where do I find the serial number on my sole e35 elliptical? Thanks !
E35 - Copied from E25 answer - on the front of the machine, right under the display, on the back side, there is a pyramid shaped piece of plastic wrapped around the middle bar. Pry it up with a screwdriver (if needed but it should slide), it should unsnap, and will reveal the mythical red serial number. And it should also be on the warranty registration card.
Sep 21, 2015 | Sole Fitness Sole E35 Elliptical
Display Problem
Yes, you do need to either replace the entire console (4 screws) or the display board.
Dec 16, 2013 | Sole Fitness Sole E55 Elliptical
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
Why did I suddenly lose resistance and smell burning on my sole e55 elliptical?
proceed according. iF THE problem persis after you LUBEt, TIME to replace the old board deck belt.God bless you
Apr 04, 2013 | Sole Fitness Sole E55 Elliptical
Sole Fitness Sole E55 Elliptical Logo
42 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
