Question about Kitchen Ranges
220 v electric oven changed oven light bulb then shorted now digital display and oven doesn't work
I have a 220volt flat surface oven.i changed the light bulb it shorted out now oven wont work and digital display dosent work either.
MicrowaveSvc
  • 9047 Answers
SOURCE: KB3300 Stainless Steel - Display not working
The control unit (circuit board) uses a relay and motor to lock the door, and the board may be damaged or scrambled
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If that doesn't fix it, it may need to have the control unit repaired. We do that for folks nationwide for only $39.95 in most cases.
We have the service manual for this model, and I've uploaded it to our site for your convenience:
www.microwavedisplay.com/kb3300js_kb3300jk_kb3300jw_sm.pdf
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 08, 2008
ngfam1
  • 639 Answers
SOURCE: I have an electric Maytag,digital
Hi Mearill,
Happy to help you!
At this site you may download a manual !
http://www.maytag.com/support/manuals_literature.jsp
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
  • 2920 Answers
SOURCE: The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Posted on Dec 28, 2008
buffalonyman
  • 1865 Answers
SOURCE: Oven digital display does not work after an electrical surge
You may want to put in a claim against the power company, a spike may have burned out the control board
Posted on May 05, 2009
  • 494 Answers
SOURCE: Electric oven does not work
After a power failure, some models will automatically resume their setting once the power is restored. On models with a clock, you must reset the clock. If the oven was in use, you must reset it by
pressing the CLEAR/OFF pad, setting the clock and resetting any cooking function.
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing
functions to work properly. The time of day
cannot be changed during a timed baking
or self-cleaning cycle.
Touch the CLOCK pad twice.
Touch the + or – pads.
If the + or – pads are not touched within
one minute after you touch the CLOCK pad,
the display reverts to the original setting.
If this happens, touch the CLOCK pad and
reenter the time of day.
Touch the START/ON pad until the
time of day shows in the display. This
enters the time and starts the clock.
To check the time of day when the display is
showing other information, simply touch the
CLOCK pad. The time of day shows until another
pad is touched.
If you do not have the owner's use and care manual,
go to this website and get a free download
of your manual by clicking on your model #.
Once you have downloaded it, you can print it up.
http://sz0047.ev.mail.comcast.net/zimbra/mail#4
Posted on May 17, 2010
How to change a light bulb on my Frigidaire oven model RT 70 light bulb in the signal light area in the surface unit switch?
Hello Heidi, thanks you for your inquiry!
From the information you have provided you need to change the light bulb inside of your Frigidaire Imperial Electric Range. This appears to be an older model and I was unable to locate any direct information on how to change a bulb. Since your appliance is older than ten years old the manufacturer may not have any information for it. You may need to perform a generic search online for further help with the bulbs or speak with a local technician. I hope this information is helpful. -Matt
Jun 02, 2015 | Frigidaire Kitchen Ranges
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
Surface lightbulbs changed but now can't turn off lights.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or two.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
May 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Nothing heats up on my maytag glasstop but the digital display
an electric range needs 220 volts for top burners and oven to work,if getting only 110 volt the display or clock will work.the most common problem i've found with your curcumstances is a burn't wire where the cord attaches to the range or if hard wired still the same place.pull out your range and inspect all wiring where range connects to house and where house connects to range.if ok take a volt meter and meaurse voltage there at cord area .if not 220 volt reading problem will be with the house.if yes 220 volts will need to trace out the range .then the problem at a place the cook top burners and the oven have in common,wire path wise.
Jan 22, 2009 | Maytag MER5775Q Electric Kitchen Range
Replacement Element does not work
If it is a double circuit element, then you will only get 110 vlolts across one circuit, and 220 volts across the other circuit..
If however it is a single circuit element, and you are only getting 110 volts, then I would suggest that you have a high resistance somewhere that is stoping it from getting 220 volts.
Hook the element directly to a 220volt supply and check voltage .
Plz rate my solution.
Thanks.
Dec 16, 2008 | GE JRP24 Electric Double Oven
I have a Frigidaire stove model number fef364dwa everything works on control panel. all surface lights work,clock works oven controls work, only the eyes don't get hot and oven doesn't get hot. do you have...
your stove is 220 volts,the lights, clock and controls, they work on 110 volts, and when there is a short on the 220 part of the stove, the elements work on 110 volts.that's the reason they only get warm. there is a short in your stove.
Dec 09, 2008 | Kitchen Ranges
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
JVM1460 surface light problem
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
Kitchen Ranges Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
