Turntable manuals HI, DOES MY PHILIPS 437 TURNTABLE HAVE A PHONO PREAMP?
BingoDabbers
  • 102 Answers
SOURCE: started playing too fast, now won't turn
Check that the belt has not perished.
Posted on Oct 06, 2007
robotek
  • 1512 Answers
SOURCE: turntable
Hi
Yup you sure do. A phono preamp also has RIAA equilisation, that reduces the treble and boosts the bass. You need this because all LP vinyl is recorded that way, and sounds terrible withpout it.
Most amps these days do not have a phono preamp. For a relatively cheap fix for the problem, you could pick up a preamp from here. Another way is to get a DJ mixer, or pick up a cheap amp of ebay, or hit the second hand/pawn shops for something to do the job for you. Happy to answer any questions you may have about it. Cheers
regards
robotek
Posted on Nov 08, 2008
  • 104 Answers
SOURCE: hum when turntable connected to phono sockets on amp
this turntable absolutely came with a ground wire that must connect to the gnd connection on the amp. maybe it got torn off or something but there should be clues on the back of the turntable as to what happened to it.
once the lead is found it must be connected to the amp gnd connect to get rid of the hum. this might require someone with soldering skilz or what have you in order rig up a new wire.
a tech might have to remove the bottom and solder in a new wire if it is cut or ripped off at the housing. This is common as people forget to unhook the gnd wire from the amp when moving things around.
Posted on Feb 11, 2009
  • 104 Answers
SOURCE: Connect a phonograph turntable to a receiver w/o phono connection
you will need a little box called a pre-amp. This hooks up between the turntable and newer receivers without a phono input. A basic explaination & drawing of this type of setup can be found here
http://www.turntableneedles.com/Pre-Amps_c_4.html
Posted on Apr 17, 2009
  • 454 Answers
SOURCE: I have a Technics turntable SLL20 and I am trying
Yes, signal from a turntable is much lower than that from tape/CD.
Posted on Nov 03, 2009
How can I connect a Thorens 145 turntable to it?
Your Harman Kardon AVR 85 doesn't have "phono" inputs. That means that you can not connect a turntable to it directly. You will need a "phono preamp" to amplify the very tiny signal from the phono cart enough for the HK receiver to play it. Something like this:
PYLE PRO PP444 Ultra Compact Phono Turntable Preamp
will do it. There are certainly better ones, like:
Amazon com TCC TC 750 BLACK Audiophile Phono Preamp Pre amp Preamplifier...
Feb 23, 2016 | Harman Kardon AVR 85
Turntable with built-in preamp won't play on phono channel on technics sadx950, but fine on CD channel. Is phono channel dead?
A turntable with a built-in preamp should not be connected to the phono input, because the preamp of the receiver or ampifier will be overdriven. The task of a preamp is to amplify the very low level of magnetic cartriges to the high level needed to work a line input and does some equalizing work to the signal. You can check if your turntable has a switch to disable the built in preamp (mostly they are low-end quality), otherwise connect the turntable to a high level input like "Tape", "AUX", "TUNER", "MONITOR", or "CD".
Nov 13, 2015 | Technics Audio Players & Recorders
My receiver works fine when I plug my iPod into it, but when I plug my turntable in I can't get any sound. Any idea?
The phono cartridge on your turntable puts out a much lower level signal than your iPod. Back when turntables were popular, all receivers had a special phono input to take care of that. Your modern HK receiver does not have a phono input, so you need to get an external phono preamp. Plug the turntable outputs into the phono preamp inputs, then plug the phono preamp outputs into one of the audio inputs on the HK, like where you connected the iPod.
Oct 08, 2013 | Harman Kardon AVR 745 Receiver
Can I connect a turntable with earth cable to an Onkyo CR515
yes you can but you will need a phono preamp such as the one found here.
http://www.turntableneedles.com/Phono-Pre-Amps_c_4.html
Hook the output of the preamp to Line 1 on the back of the CR515 and for simplest ground wire hookup, choose a preamp with a thumbscrew for the ground (earth) cable coming from your turntable.
Feb 16, 2013 | Onkyo Audio Players & Recorders
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Aug 01, 2012 | Marantz Nr1402 Av Receiver
Good afternoon, have just replaced my stylus, an11, but on playing the sound is distored and "tinny", prior to the new stylus is was crystal clear..have tried a 2nd new stylus and still the...
Disregarding the narrative about the stylus damage, did you disconnect the TT from the electronics to work on it and then plug it back into something OTHER THAN PHONO? Only PHONO or somethign with a phono preamp supports a TT.
There is also a switch on it called "equalizer amp" that activates its own internal phono preamp. It could be in the OFF position by mistake if you're not using an outboard phono preamp.
As they say - RTFM...
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Aug 17, 2011 | Aiwa PX-E860 Turntable
PL-88FS with modern HDMI Receiver
Hi...
If the new receiver doesnt have a specific input in back labeled "phono" , You WILL need a preamp for the phono. Then plug the preamp into the AUX or other available input
Jan 18, 2009 | Pioneer PL-990 Turntable
Turntable problem
You will need a phono preamp. Ipods, radios and cd players all give out a LINE level signal..which means you can plug headphones or speakers, adjust volume and be set. A turntable needs a phono preamp. Usually a dj mixer or stereo receiver with a phono input is all that is needed. A simple phono pre amp is like $20 from radio shack.
keep me posted.
Oct 25, 2007 | Gemini XL-500 Turntable
 Grubhead
Grubhead
