Question about Toshiba 1370 Black and White Copier
Showing toner not printer
MFC-7840W Printer Brother, we have replaced the toner many times and the printer always shows the message on its screen: low toner, and after that shows: toner life end, what we can do, because this is the...
Open the front cover. Remove the drum and toner. Remove the toner from the drum by pressing and holding the green/blue tab on the right side then lift the toner out. Shake the toner side to side for 6 times, and on the drum unit slide the blue/green tab on the far left side from left to right for 6 times also. reinstall the toner back to the drum unit. reinstall drum and toner back to the machine. Close the front cover. The display should show the date and time.
Hope this will help.
Mar 25, 2011 | Brother MFC 7840W Printer
I have SCX4300 printer. It shows TONER EXHAUSTED , REPLACE TONER Please provide the solution
Jan 01, 2011 | Samsung SCX-4300 Monochrome Laser...
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
Samsung scx4200 toner problem
I refill the toner for samsung scx4200 .Now its show toner empty replace the toner on the printer lcd. How i can slove this problem.
Jul 09, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Scx4300 toner exhausted problem
It sounds like you need a new Toner cartridge
Jun 24, 2009 | Samsung SCX-4300 Monochrome Laser...
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
HP 2600n printer showing empty black toner
maybe u have to reset the printers counter..
Jul 22, 2008 | HP Color LaserJet 2600n Printer
False detection of toner low
The only remedy you have now is to change the sensor , for this you have to refer to the product manual you can download it from
http://www.brother.ca/en/products/pdf/QSG/HL2030-QSUG.pdf
Good Luck
Dec 05, 2007 | Brother HL-2030 Laser Printer
Toshiba 1370 Black and White Copier Logo
18 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
