Question about Dryers
Roper model red 440sq0 heat
Dryer won't start
  • 159 Answers
SOURCE: roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Posted on Aug 22, 2007
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
SOURCE: dryer won heat timer dosen't avance
9 times out of 10 check your fuses there r usually 2 for your dryer that most people dont know about 1 of them is for the power and the other one runs the timer and heat
Posted on Aug 27, 2009
Illeagle
  • 525 Answers
SOURCE: roper dryer won't heat up.
Before you start diagnosing your problem, ascertain that you have made a proper and positive heat selection on the control panel, then proceed.
Below is a link courtesy of www.repairclinic.com, which shows disassembly/diagnostic procedures.
http://www.repairclinic.com/Dryer-Electric-Whirlpool-Style-Version-2-Appliance-Diagram
A volt-ohm meter (VOM) will be helpful in diagnosing most issues.
http://www.ehow.com/how_2076998_use-voltohm-meter-safely.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
Purchase a VOM
http://www.omega.com/ppt/pptsc.asp?ref=HHMA&Nav=vhtj06
Below are the next 4 common failure modes to check.
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If all the above checks allright, then proceed to the next steps below.
Thermal overload/cutoff thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%
3d%3di2651&PartID=2651
Cycling thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2893&PartID=2893
Motor Centrifugal Switch.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2584&PartID=2584
Heating Element Connection Wire.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di3140&PartID=3140
Timer.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di548371&PartID=548371
Posted on Sep 21, 2009
SOURCE: Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Posted on Feb 07, 2010
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
My dryer won't start unless i find the right spot
Hello would you happen to have the model number of your dryer? It sounds like you actually have two issues one being the timer itself and the other being either a hi limit thermister but the timer would be the last thing that you would test. If you happen to have a multimeter when you message me back your model number I can locate your schematic showing which parts that you would test by assuring each has continuity.Here is also a video on basic ways to test and diagnose heat issues with a dryer click this link http://www.youtube.com/watch?v=f1rebeCMVsk if you have any questions message me back those as well. I await your reply Thanks
Rick
Sep 16, 2011 | Roper Dryers
Hi i have a roper electric dryer and it will go threw all the cycles but wont dry clothes like wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 05, 2010 | Roper REX3614KW Electric Dryer
Dry run no heat
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
May 15, 2010 | Roper REX4634KQ Electric Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
heatman101
Mar 30, 2010 | Roper Dryers
Roper Gas Dryer
hi first thing to do is clean all the venting and try again. thanks the appliance doc
Apr 19, 2008 | Roper RGX4634KQ Gas Dryer
Roper dryer won't heat
Aug 20, 2007 | Roper REK2950W Electric Dryer
Dryer won heat timer dosen't avance
huntman, the model posted shows as a gas dryer. In the lower left side there is a square plastic peep hole. Take a putty knife and pull it off. Set the dryer to high heat and take a look in the hole. Does the ignitor glow? If it doesn't you either have a bad thermal fuse or a bad ignitor. Start with the thermal fuse. You will have to remove the back panel to get at it. I will attach a photo. You can ohm it out, or just jump the wires temp. to see if the ignitor glows. If theral fuse is good and the ignitor does glow, you probabley have a bad set of coils. These sit on the gas valve are easy to replace. The timer won't advance without the heat. Check this out first...Catriver..post back.
Mar 15, 2007 | Roper RGS7745PQ Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
