Question about Acer Aspire Z5801 All-In-One Desktop PC Intel Core i5-2400 Processor, 4 GB RAM, 1 TB HDD, Digital TV Tuner, NVIDIA GT520, Windows 7 Home Premium with 24 inch Multi Touch Screen Monitor
Fan noise is there a replacement quiet one available?
My 4 door smeg is making loud high pitch shrill noise with quiet knocking coming from the back of the fridge by the compressor and is very hard to listen to what is it?
you just bought it as in new ---get a technician out under warranty---or new to you but second hand ---get a technician out for a proper diagnosis and a quote
May 30, 2016 | Smeg Dishwashers
Refrigerator noise
cause of this problem is grated shaft bush of compressor. replace compressor
Mar 14, 2014 | Home
Fan noise Slide Projectors
Fan noise on a Carousel 4200 Slide Projector is usually not the fan at all - - it is usually caused by the fan or mechanism drive belts (they stretch out and loose their elasticity over time & wear). Replacing the belts and re-greasing the fan axle should quiet the projector down nicely. The belts can be purchased from: www.micro-tools.com
Words of warning:
* This replacement will require an almost total disassembly of the projector.
* Do NOT interchange the belts!!! They are size-specific.
Jim
Feb 12, 2014 | Kodak Office Equipment & Supplies
RCA RT2770 fan is making a lot of noise. Started off quiet, but it's been getting louder and louder, now more so than the volume of the movies I watch. Should I clean it? Replace the fan? Junk the...
Do one thing, Remove the fan from the player. In the fan there will be a specification sticker. Remove the sicker. Now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. You can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the player. power ON the player and watch. If available then try to replace the same. it will not cost a lot. just watch the following video for oiling the fan. its for a PC fan same for all dc fans.
ok
Apr 01, 2011 | RCA RT2770 Theater System
Can anything be done about the load fan noise I am experiencing now?
Yes.
You should be able to obtain ultra quiet fans from your closest electronic parts shop.
If you are not comfortable replacing the fans yourself with the ultra quiet ones, most TV repair shops will do it for a small fee.
Feb 28, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
I replaced the clutch fan in my 2001 rodeo,manual tranny, but the problem is still there, the fan is always on, it sounds like a tractor trailer, the fan will go off after 10 min of driving ,when you get...
usually two types of clutches available,one engages with heat,the other is rpm controlled. The thermal clutch will stay quiet until the engine temp gets too high. Centrifical clutches seem to make more fan noise.
Aug 21, 2009 | 2001 Isuzu Rodeo
My Emachine Fan Way to Loud
... this may be worth a try; it worked for my noisy emachine fan.
First open the box and vacuum out any dust on the fan. I also opened my power supply and did the same; there was quite a bit of dust, so you can imagine the heat never got the chance to be removed. Also, on my machine, underneath the CPU fan, there's a metal baffle; get the dust out of this as well ... same problem re. removing the heat. Last... and I'm not sure this matters or is true, but, for my fan, the power supply plug on the motherboard seemed to accept the plug oriented 180 degrees different from the way it was plugged in from the factory ... could this change the direction the fan blows? It certainly explains the bizarre build-up of dust in my CPU baffle. Once I did this, the fan goes up to 100 percent for about 3 seconds on boot, then it has never 'noised-up' like it used to! ... it's totally quiet now and the computer works great...
good luck
Dec 20, 2008 | E-Machines eMachines T3830 PC Desktop
GX280 - is it the motherboard?
Go here and download this program.
http://www.download.com/SpeedFan/3000-2094_4-10067444.html
This program will control your fan speed based on your cpu temp. It's main use is to quiet fan noise.
Dec 15, 2008 | Dell Optiplex GX280 (99301) Motherboard
I replacement fan
They sell some things that you can put on the fan so it can run quietly without making any noise.
Oct 28, 2008 | Gateway 506GR PC Desktop
Wine cooler noise
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Acer Aspire Z5801 All-In-One Desktop PC Intel Core i5-2400 Processor, 4 GB RAM, 1 TB HDD, Digital TV Tuner, NVIDIA GT520, Windows 7 Home Premium with 24 inch Multi Touch Screen Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
