Question about Bernina Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
Bernina 1030 sews perfectly with full speed control and parks the needle on top when foot pedal is released. If the pedal is depressed backwards the needle goes down an d parks there. After the sewing is stopped and the needle is parked at the top the machine starts running by itself at a very slow speed. I t doesn't happen every time and doesn't do it right away. the only way to stop it is to remove the control foot plug.
    Scholar:
  • 74 Answers
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Posted on Feb 04, 2015
  • 166 Answers
SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Posted on Jan 02, 2009
  • 69 Answers
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Posted on Feb 09, 2009
bargainbox
  • 1388 Answers
SOURCE: Today the machine started sewing by itself! My
There is a supressor, usually in the foot control that has burnt out. Not dangerous, quite a;arming tho' If you can remove the burnt unit yourself that's fine, but if you are in any doubt, ask a service centre for a quote to remove ot for you, or a qualified friend etc.....it is not essential, just reduces interference on TV and Radio while you sew in the same house.
It is mains power, so don't fool with things you don't understand.
Posted on Sep 04, 2009
  • 980 Answers
SOURCE: singer 522 starts sewing at speed without the
Undo the foot control and take out the small square suppressor and throw it away, you don't need it anymore.
Posted on Dec 18, 2009
Tally Girl
  • 1129 Answers
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Posted on Jun 12, 2011
I have a Bernina 1030 and the size of the straight stich knob is jammed it willonly turn back to 1 which means it will not straight stich just a small zigzag. Can you please help.thanks Joy
I suspect the machine's stitch selector mechanism has seized due to old, dried oil. (I have a 930 and several older Bernina models, and oiling thoroughly and frequently is necessary to keep these nice mechanicals running smoothly.) However, if the knob on the straight stitch selection lever is frozen, you may need to take it for service if you are unable to free it on your own.
Wheel on right side that controls the needle up and down is very tight...
Aug 08, 2017 | Bernina Sewing Machines
My bernina 707 minimatic..isn't working!! My needle keeps getting seized an won't move up an down...Then when i try to sew it sews blanks....
Replace the needle.
Make sure the needle is inserted the right way. If the needle is installed the wrong direction the machine will get stuck.
Check and correct tension of the bobbin. (Guide attached)
Start the top tension at four and adjust as needed.
When threading do it with the pressure foot up so any snags can be felt. If there are snags they must be corrected. While threading, little tugs of the thread along the way will help. The snags can be felt this way.
Aug 25, 2015 | Bernina Sewing Machines
Can you use twin needles on bernina 1080
I have a Bernina 930 Record that will take twin (even triple) needles, so I don't know why your 1080 wouldn't. Just be sure your machine does not have the straight stitch plate on it, that your presser foot can accommodate zig-zag stitch, and that you carefully adjust any zig-zag stitch width so the needles do not hit the presser foot or stitch plate. I'd suggest installing the double needle and then carefully hand rotate the handwheel to see if the needles will hit anything. If you can make a full rotation of the handwheel without anything hitting, then slowly try it with the motor engaged.
Feb 23, 2015 | Bernina Sewing Machines
My bernina 1030 is not feeding the fabric, it is sewing in one place
Make sure your feed dogs are not set for free motion or darning. Once you switch them to regular sewing you will need to turn your hand wheel 1 rotation for them to come up. Also make sure that your stitch length is not set at 0.
Jan 07, 2015 | Bernina Sewing Machines
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have a 1030 Bernina sewing machine and for the first time in 10 years the needle will not move up and down. It will go side to side. It stopped while sewing and won't restart. I have checked all of the...
Take it to your Bernina dealer, they should be able to determine what is wrong and hopefully fix it, free. You really do not want to do something that could void your warranty. My Bernina dealer is super nice and always helpful, they are very professional. I hope that it is just some silly thing, like mine was.
Apr 03, 2011 | Sewing Machines
BERNINA 802 BOBBIN THREAD WILL NOT COME UP THROUGH THE NEEDLE HOLE
try this
first make sure the needle is not damaged
make sure there is a 3-5 inch tail for the bobbin thread
make sure there is a 3-5 inch tail for the top thread & hold the top thread tail with your fingers (away from the needle) now with your other hand use the handwheel on the right side of the machine to slowly lower the needle down to the bobbin area & see if it will pick up the bobbin thread
Sep 25, 2010 | Bernina BERNETTE 65 Mechanical Sewing...
Sewing Machines Logo
153 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
