Question about Refrigerators
Kenmore 795.75292402 freezer not working
Freezer quit working properly
My Kenmore up right freezer is not working properly. The fan in running however the condensor will come on for a few seconds and then turn off. The food is thawing out in the freezer and water is dripping...
When you say condensor you probably mean compressor. If the big metal motor at the back is making that noise that is your compressor. The compressor is either bad or the relay for the compressor is bad. I recommand replacing the relay first since it is your cheapest solution and then if that doesn't solve it then you can decide if you want to replace the compressor or not as this is not something you can do yourself and can be quite costly to do if you have a technician do it. Hope this helps.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 21, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore upright freezer. left and right outside box sides are fairly warm. Is this common?
yes. This is the way freezers work. Every freezer will do this. If the freezer doesnt do this it generally does not work properly. So to answer your question... its nothing to worry about.
Jul 01, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Kenmore elite bottom freezer refrigerator...water won't work
I turned up the temperature in the freezer and the refrigerator. The next day the water was flowing.
Thanks for your time.
Sherry Piper
Jan 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
Jan 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore fridge
First we need to see if the compressor is running.  Pull the fridge out take off the lower panel on the back and see if you can hear it running.  Also, need to know if freezer fan and fan by compressor is running.  Check for thick frost build up on back panel in freezer.  Let me know what you find.
Oct 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
