Question about HP Pavilion dv1000 Notebook
Dead, not working in battery & adapter
  • Varghese Cg
    Varghese Cg Feb 07, 2014
    sir, i checked voltage of adapter, and i checked voltage of mosfet pq44(Ao4407)pins 1,2,3. there voltage is 18.4v, but no voltage com out from its other pins (5v,3.3v)and power on light not working in mains and battery. its model-hp dv1000 laptop,
    thanks& regardings
    Top Expert:
  • HP Master
  • 22,152 Answers
Being an Hp, I would look at the GPU. It has probably been cooked.
Posted on Feb 07, 2014
2 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: battery or ac adapter problems?
The power jack on the system board may be loose or disconnect. The only way to check it is to plug in the AC adapter and wiggle the connector , if it feels loose then that is the problem. The other way to find out, is taking out the motherboard and checking it.
The fact that the battery was charged when you receive it tells me that the seller knew about the problem. He probably held the adapter plug in such a way that the battery got charged.
Joe
Posted on Nov 21, 2008
Worked off the battery but it wont charge or run off power cord adaptor
Check and make sure the power adapter doesn't have a fuse somewhere in it. Then chk the wattage output of the adapter. Watts should be marked on the adapter.. Now see what the computer requires. Computer info is on the sticker on underside of computer.To determine how many watts the computer needs, Note the amps the computer draws(on label) and multiply the volts(on computer again) x the amps. Answer will be your needed wattage.
Use only the adapter that came with the computer. They may look alike, but there is a difference. Make sure the computer is powered off. A full charge is needed now since the battery was dead. Allow time and don't use the machine prematurely.
Make sure the adapter output matches or betters the requirements of the computer.- Good Luck-Ned
Jul 23, 2014 | Barco R9852000 LC40 Compact PC (R98 52000,...
How to open trunk without key WHEN BATTERY IS DEAD I TRIED THE CIGERTE LIGHTER JUMPER CABLES IT DID NOT WORK I HAVE A 04 LINCOLN LS
Read my other post to your other question
If the doors are open,drop the back right seat back,
& crawl into trunk & pull the yellow release tab
OBD2 Vehicles do not use the lighter for battery voltage,
that was obd 1 systems ,the power is in the diagnostic connecter
by your right knee,need adapter to use battery KAM memory
back -up
The seat may only be released from the trunk--.have to check my 2004 LS
Feb 07, 2013 | 2004 Lincoln LS
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
My Acer Aspire one notebook ZG5 won't turn/boot on, help?
1. Dead AC adapter
2. Dead battery
3. Broken AC-socket on laptop, so no power is received, and battery is not charging.
4. Dead ON/OFF switch
5. Dead motherboard
Take your computer to a qualified technician, for professional trouble-shooting & remediation.
Jul 19, 2011 | Computers & Internet
Acer Aspire 5610Z dead battery & malfunctioning power adapter
But before you buy a new battery, You need to again repair the power plug where your adaptor's plug is inserted so that it will not create any problem later. There might be loose connection or sort wiring.. Good luck..
Apr 29, 2010 | Acer Aspire 5610 Notebook
Will the aspire 5735 start up with a dead battery
A dead battery will usually stop a laptop from starting up. Remove the battery and try running from the power adaptor alone. If this works you can be sure the battery is dead.
Apr 10, 2010 | Acer Aspire 5735 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Compaq presario 2200 dead after switching battery No power or lights. All I did is change out the dead battery for a new one.
u can try only with ur adapter ur laptop go on? if work u can change new battery of dunt work may be from the electric in ur motherboard
Jan 16, 2010 | HP Compaq Presario 2200 Notebook
Laptop is not switching on..no leds turning on ..dead!
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 23, 2009 | Acer TravelMate 2300 Notebook
HP Compaq nc6220 Laptop is dead. no lights,
Is this the same if the charger is also plugged in??
Remove battery and retry with charger plugged in.
If same battery charger is faulty.
Dec 22, 2009 | Compaq Hewlett Packard nc6220 PC Notebook
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
