Question about Toshiba Mk Computers & Internet
Sata hardisk jumper is broken - Mk Toshiba Computers & Internet
3 Suggested Answers
  • 10406 Answers
SOURCE: did not detect the additional sata hard disk?
Have you tried connecting the SATA hard-drive to a different computer, just to prove that it is not a "dud" ?
Is the SATA hard-drive getting power?
(It should warm-up a bit, and you make feel it vibrate as it spins.)
Have you tried a different SATA cable between the hard-drive and the SATA connector on the motherboard?
Check the BIOS settings, to be sure that detection of SATA drives is "enabled".
Posted on Apr 09, 2010
SOURCE: sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Posted on Jul 29, 2011
Testimonial: "Thank u"
Sata hardisk is not working "usb not recogenised"
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
SATA Hardisk canot read into bios.. the sata cable is brandnew and SATA hardisk is also new
You will need a RAID driver for your motherboard. Contact your motherboard manufacturer for assistance.
May 23, 2011 | Computers & Internet
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
How do I install my new hard drive as a slave to get additional storage?
Look your hardisk there in a jumper like blue color or any look at the top of your hard disk where to put the jumper to slave and another hard disk to master. but use this setting if you using one cable like IDE. but if use sata just put your sata cable to sata slot in your motherboard. follow the no. of your sata slot.
Oct 06, 2010 | Western Digital Computers & Internet
Did not detect the additional sata hard disk?
Apr 09, 2010 | Computers & Internet
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
Not ditect SATA HARDISK
Hi
I know what is problem,some of mother is made only SATA HDD data transfer rate 1.5 GB per second.Now all are SATA HDD data read rate 3 up to g GB per second .Follow the instruction label on the hard drive.
If you use your Motherboard 3GB data read hard drive you can customise setting jumper source of data rate 1.5 then MSI Motherboard detect SATA hard drive.
Good Luck.
Nov 26, 2009 | Intel Motherboard
I cannot install software
Hi..
This happen due to 3 reasons,
The Hard drive is bad.
The BIOS Setting have to be put to SATA.
During the the installation the have to press the F6 option to install the SATA drive drivers.
Let me know
Thanks
Smith
Aug 09, 2009 | ASUS P5LD2-VM Motherboard
Need SATA hardisk driver for DOS
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
SATA HARD DISK DRIVERS FOR DOS
OR
DOS HDD DRIVERS FOR SATA
OR
DOS DRIVERS
OR
DIRECT OPERATIONAL SOFTWARE
ROD
Mar 05, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
I have a new 8ogb sataII Exelstor hardisk which i
Windows XP does -not- have native SATA support and therefore will not recognize a SATA drive without first installing 3rd party drivers.
To go around this problem without installing drivers check your BIOS. There might be something in there where the bios will emulate an IDE controller.
If not, you'll need a floppy and the sata drivers. A flash drive will also do if the motherboard bios supports legacy USB. To find the drivers, simply go to the motherboards manufacturers website.
Mar 03, 2009 | EPoX EP-8KRAI-X Motherboard
Computers & Internet Logo
122 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
