Question about Breville Hot Cup With Variable Dispenser 2lt Black
Breville Hot Cup VKJ318
I've had this kettle for about 3 - 4 years now. It has started to not turn off after boiling and dispensing. The power button looks to be sticking. Is there a way to clean it?
4 Suggested Answers
  • 274 Answers
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Posted on Sep 11, 2007
SOURCE: filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
Posted on Feb 26, 2009
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
Breville one cup filter kettle intermittently switches off before boiling . It will work if I keep the button depressed.
Oxidized or worn thermo-switch contacts.
Or, sometimes old age (kettle!:) or overheating can cause springy contacts to bend out of shape.
Get tech-minded person to open/inspect & renew as required.
Jan 19, 2017 | Breville Kitchen Appliances - Others
Vkj476 BReville hot cup with variable dispense. How do you change the filted britta filter
The Breville VKJ476 Hot Cup with Variable Dispenser does not require a filter so will not take a Brita filter.
Mar 21, 2013 | Breville Hot Cup With Variable Dispenser...
How to descale a breville one cup
NOTE: Not my instructions i just found something similar.
According to the instructions for Breville Hot Cup (presumably similar to yours - the adjustable flow one):
1. Fill it to the max and dispense one cup of water.
2. Add a citric based descaling product into the cup and stir.
3. Tip contents into kettle and close lid.
4. Dispense water from the kettle, discarding the water until it reaches the 'min' mark.
5. Empty remaining water into sink, rinse out with clean water.
6. Fill kettle with fresh water and dispense cups of water until it reaches the 'min' mark. Empty the rest into the sink, then refill ready for use.
Nov 24, 2011 | Breville Coffee Makers & Espresso Machines
Breville hot cup
Breville Hot Cup spitting:
Hi Louise.
My HAZ upright kettle did the same thing recently.
Sounds like your element-tube has a rust-hole, which allowed water to enter the normally dry and cozy filament area. The water that seeps inside hits the red-hot filament, vaporises to steam which violently expands out of the pinhole.
Remove element, check for corrosion, renew.
Hope this helps. Clive.
Oct 09, 2017 | Breville Kitchen Appliances - Others
How do you clean a Breville JK73 kettle. I have lost the instructios.
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
How to clean out a breville hot cup?
1/2 vinegar & 1/2 water bring to boil and sit for 10 mins then boil with fresh tap water and as pour away.
All should be then OK - it works for us in West Aust!
Oct 21, 2009 | Kitchen Appliances - Others
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Breville Hot Cup With Variable Dispenser 2lt Black Logo
75 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
