Question about Electrical Supplies
Where do I find the force adjustment on a digidoor 2 controller
Digidoor II. Why does it move a few centimetres then stop?
i would suspect one of two possibilities:
1. down stop is set incorrectly
2. down force is set too light.
Jul 17, 2015 | Building Materials
Can i fit 12v battery backup for digidoor 11 to open when there is loadshedding. My digidoor2 had the extra consoke for remote receiver
Nope, Digidoor II has no battery backup. You need to invest in a UPS or replace the motor.
Digidoor one, Digidoor III and the Digidoor IQ all have build in battery backup.
__________________
Reference:
http://www.4x4community.co.za/forum/showthread.php?t=142874
Jun 13, 2015 | Computers & Internet
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
How do I check the obstruction function on Digidoor 2 please
Look on the side of motor you will see hex screw that has a ^ sign that means up and another one for down.you set the collision force with it. Clockwise then the force is greater before it stops. Anticlock means it takes a little force to stop it
Sep 09, 2014 | Building Materials
How do i programme a digi key remote to my digidoor II garage motor, my original fell and no i bought new digi key remote. plz help
How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Apr 22, 2011 | Audio Players & Recorders
My digidoor 2 opens fully but only closes a small distance before re-opening
It sounds like either something is blocking the electronic eyes (or maybe the lenses are dirty), or the down pressure adjustment is too low (it might need to be re-adjusted).
There are usually several adjusting screws on the head of the unit itself. They should be labled.
The instruction manual should also explain how to do this if you still have it.
Also, the electronic eye sensors might need to be re-aligned.
Good Luck!
Jan 23, 2011 | Garden
I have a digidoor 2 automatic garage door and it closes in stages not in one motion. The problem started when I stopped the closing motion half way down by remote control to let someone in. Up until then...
It sounds like your obstacle setting might be set too low and the friction of the door is causing the motor to stop. There are two white alan key adjustments on the side of the motor that can be adjusted to change these settings for the up and down sensitivity. If this does not solve your problem contact the Digidoor technical helpline on 2711 4749060, they will be able to assist you.
Aug 24, 2010 | Kitchen Ranges
Digidoor 3 garage door only opens about 60cm and stops. Was not given a manual by installer.
The problem might actually be the door itself. make sure it raises and lowers easily and is well balanced. If it is then find the power adjustments and turn up the up force to work the door. Do a 2x4 safety reversal test afterward. Thanks BB
Aug 24, 2010 | liftmaster Chamberlain Garage Door Opener...
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
