Question about Acer Computers & Internet
Acer heating very fastly and shutdown in 30 minuites
I have a poblem of overheating and getting shut down in 30 min.So i had taken to service center.He said chipset problem.Is that true??If so how much cost it wiil be to get repair
    Top Expert:
  • Acer Master
  • 25,303 Answers
I would clean the heat radiator and fan first. If the "chip set" were an issue, I suspect it won't work at all.
Posted on Feb 07, 2014
  • 13433 Answers
SOURCE: my acer aspire 5772 shut down
The motherboard must be faulty for them to give you that advice. you can look for people who actually repair those motherboards or replace it.
Posted on May 19, 2009
  • 104 Answers
SOURCE: automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Posted on Aug 01, 2009
ravin4
  • 15 Answers
SOURCE: shut down with no reason
Disable some of the unnessary services being run at the background. eg. DHCP etc
Posted on Aug 08, 2009
  • 199 Answers
SOURCE: Abrupt shutdown of Lenovo 3000 Y410
motherboard thermal section problem
joe
Posted on Nov 03, 2009
  • 10 Answers
SOURCE: sony vaio system becomes hot and shutdowns
More than likely the fan above the processor is not working. Or the vents are clogged on the computer case due to dust/dirt. Ventilation.Check the fans.
Posted on Nov 22, 2009
Unexpected shutdown with my acer laptop
if it keeps shutting down/ CRASHING and then it goes to a blue screen leave it for about 30 mins and if it does it again get your RAM upgraded from whatever GB it currently is to about 4, 5 or 6 GB!!
Aug 05, 2013 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
Asus netbook shut down
It could be a heat issue. Overheating will shut down a system real fast. If this is new system I would recommend to contact Acer A.S.A.P. and tell them to either fix the issue or you want a new one
Jul 09, 2013 | Computers & Internet
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
Tv will shut off after 30 minutes- sony brand
try cleaning the filter. sometimes when the filter is dirty it heats up fast and shuts the TV down.
This is because the video ic is heated up and automatically shuts down to prevent overheating.
G
Jun 06, 2011 | Sony KP-57WS500 57" Rear Projection...
I have and ACER aspire 5738G (1yr old now), everytime im playing games, the left portion, exactly below the power button is getting very hot after 30 mins, then my laptop will shutdown.
Games will cause more heat as they put your components under more stress. Make sure that you are not blocking any of the vents and also, check them for dust. Give them a vacuum if they are dusty. It sounds like there is not enough ventilation, which causes your computer to overheat and then to shut down.
Feb 04, 2011 | Acer Aspire 5735-6694 Notebook
Projector shuts down after a couple of minutes with lamp and temp lights flashin, is this a fan poblem and can i replace the fan?
This probably the fan is not cooling down the temperature of the high intensity bulb. Due to overheating the bulb will shutdown. Get a correct specification fan to replace the aging fan.
May 30, 2010 | Acer PH110 Multimedia Projector
Acer aspire overheating & rstarting.
you can replace the fan if you know how to do so but take it to a qualified technician and they will be able to sort it out for you and it should be that expensive
May 29, 2010 | Acer Aspire 5100 Notebook
Acer laptop goes off after 30 minutes exactly. wont come if i try immediately but after about 5 mins comes on when I power it. help
you have set ur computer to sleep or hibernate after 30 minutes of inactivity. you can customize this in you power setting.
Control Panel-> Power Options
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5610z
need more info....does it replicate without the battery? If it does, then it may be that the processor is overheating and shutting down the computer. Try to run with just the power adaptor and see if it happens. If it doesn't, then its probably the battery....
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
Acer travelmate 2420
It could also be the CPU "heat sensor" causing a "thermal" shutdown.
Try a hairdryer on cold blow, and point it in where the CPU cooler is!
see does the laptop stay on longer. Thermal paste dosen't usualy "go" unless the heat sink has be detached from the CPU.
I think as you say either the fan or I think the heat sensor.
Aug 22, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
