Question about HP Photosmart C3180 All-In-One InkJet Printer
No hp devices detected - HP Photosmart C3180 All-In-One InkJet Printer
No HP devices detected. HP Solutions Center will close now.Need HP 7500 devices.
remove the incorrect 7500 driver and install hp universal driver after install have it search for your printer or manually configure it yourself which ever is easiest for you .please reboot your computer after removal of incorrect driver
Feb 18, 2014 | HP OfficeJet 7410 All-In-One InkJet...
No HP devices detected. HP Solutions Center will close now. I have installed and uninstalled still saying No HP devices detected. HP Solutions Center will close now.
Did you follow the prompts to turn on device and connect the USB cable at the correct time in the installation process? Check your USB connections and cable.
Jan 13, 2011 | Computers & Internet
I just bought a hp deskjet f4280. when i click hp solution centre a message (no device have been detected. hp solution centre will close now.) displays i have tried everything nothing seems to work
*** UNPLUG THE USB CABLE********
just insert the disk and then click on add a device
dollow the instruction
plug in the usb when asked
and if the printer detection goes fine and the installation is successfully completed
the issue will be resolved
Nov 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
when it hangs,right click the task bar and open task manager and from the process tab stop the file wrapper.
In device manager click on view and select show hidden devices.
U will see and imaging device keep updating it and
Oct 22, 2008 | Office Equipment & Supplies
No hp devices have been detected. hp solution center will close now
hi petenam,
since you posted this 10/17/08, it's probably no longer an issue for you... but jsut in case someone else is runs acorss the same issue and comes by your post, here are a couple links for future refs (from HP's support site) that might be helpful.
hp solution center and product defaults:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00787813&dlc=en&product=441125
no HP devices detected via solution center:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00762521&dlc=en&product=441125
no devices messages running Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01529081&cc=us&lc=en&dlc=en&product=441125
general support issues link for your product:
http://h10025.www1.hp.com/ewfrf/wc/product?product=441125&lc=en&cc=us&dlc=en&lang=en&cc=us
-JW50
Oct 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Device Not detected for printer HP D4168
The driver for your printer must be VISTA compatible, if not your printer or devices will not work
Oct 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
14 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
