Profitter heater my profitter 170,000 will run but runs rich and starts spitting kerosene out with the flame
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
steve_lima
  • 181 Answers
SOURCE: kerosene heater won't stay lit
check to see if the photo cell is clean.to check it open the side compartment and look for the blue and white wire comming from photo cell,on the reset switch there is a white wire and a blue wire.hook these two wires to gether at the switch and try to refire the unit.if the unit keeps running the photo cell is bad and NEEDS to be changed.if the unit shuts off the safety switch is bad.
Posted on Feb 25, 2009
  • 188 Answers
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jun 30, 2009
heatman101
  • 43501 Answers
SOURCE: Lawn Boy Kerosene Torpedo Heater, ph100 it sort of
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
heatman101
  • 43501 Answers
SOURCE: Reddy Heater 60k kerosene suddenly smells
heatman101
I have a profitter 210,00 btu fires but wont light what should the pressure gage read?
I'm guessing this is a kerosene forced air heater. the pressure for a 210k pro fitter is 8.5 psi.
Jan 13, 2012 | Heating & Cooling
Heater is running very rich
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Jan 11, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
My reddy heater will run for a little bit then "flame out' with the light by the "flame" button blinking.
Clean the lens of the photocell - electric eye- Check pump pressure on back of motor at pipe plug
Nov 12, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Have john deere 50 kerosene space heater has fuel,new plug,
if it trys to start when you turn the thermostate then thats not the problem, it has to be either the high heat limit control or the flame sensor. Mine did the same thing and I also thought the eye was working but as soon as I changed it the problem was solved. Pretty much all flame sensors are the same and you can get one from Mr. Heater for less than 3 bucks, same with the limit control.
Jan 23, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Flame light flashes after unit runs for awhile.
Check for spark and clean your plug. If you have good spark it's one of two things, the high heat limit control or the flame sensor, my guess would be the flame sensor.
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Dec 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
