Question about OKI B4400 Printer
Oki b4400 default password - OKI B4400 Printer
3 Suggested Answers
richard191
  • 691 Answers
SOURCE: I need to hook up my printer, I don't have a disk.
http://my.okidata.com/PP-B4400.nsf?opendatabase
go here and input what OS you are running
Posted on Nov 19, 2009
drifterK
  • 4924 Answers
SOURCE: HOWcan hook up compjuter printer oki b4400
just plug it into the computer printer port ..or on usb after case..and install the driver cd ...make sure the driver it is suitable for the operation system you are using in the computer cause for elder models the cd came only with xp drivers and if you have Vista you will have to look for the driver at the manufacturer's support site ..
after you install the driver and the printer is plugged and on ...just restart and go for it ..
http://www.okidata.com/mkt/html/nf/Drivers.html
select it from the mono page printer section..
Posted on May 28, 2010
B4400 won't pick up paper
Never use spirit to clean rollers. Just fairy liquid and water. All the roller gets is grease from the paper on it. Fairy liquid is the best degreaser. Alcohol will soften the rubber and it will work short term and then the roller is finished and will need replacing.
Feb 15, 2014 | OKI B4400 Laser Printer
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
Drivers
this is the OKIB4400 Direct link for the drivers
select ur Operating system if xp vista. or 7
then select language then download it. and install
Dec 26, 2009 | OKI B4400 Laser Printer
I need to know OKIB4400 LASER PRINTER; TRIANGLE W/ EXCLAMMATION
This is an "Attention" indicator. Has a lot of meanings when blinking and all of them described in the user's guide. There is also Status Monitor Software that can be installed after the printer driver and which displays printer status on the PC's screen. Much more convenient way to get information from the printer than deciphering indication of the lamp in question.
Jun 05, 2009 | OKI B4400 Laser Printer
I want to change the ip address on an okidata printer b4400.
Try the default username of admin and the default password of - OkiLAN and the password is supposed to be case sensitive. Let me know if that helps and good luck.
Mar 18, 2009 | OKI B4400 Printer
New fuser - do I need to reset
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
Oct 07, 2008 | OKI B4400 Digital Mono Printer - Black
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
OKI B4400 Printer Logo
51 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
