Question about Seagate Momentus 5400.3 Hard Drive
Seagate 80 GB laptop hard drive not appearing in My Computer
I have recently purchased a Seagate 80 GB Laptop external drive in a 2.5" USB casing. This is recognised by my Lenovo laptop with VISTA HOME and working perfectly. But when I am trying it in my desktop (WIN 98 SE) the computer hangs even after loading the required drivers. It is also not appearing in another laptop with WIN XP Prof SP II. What should I do to overcome this problem?
  • SDGG Oct 30, 2007
    My main computer i.e. the desktop runs WIN 98 only. I feel that the disk is formatted as NTFS in the VISTA m/c. It is showing in disk management tool of the Laptop with WIN XP as "Protected Volume" and not appearing in the My Computer of the XP Laptop with FAT32 file system. Should I format the drive in the VISTA Laptop as FAT32? Will that solve my problem?
  • 188 Answers
I suggest u to re instal u r
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Posted on Oct 26, 2007
Seagate ST9808210A locked no password entered
Contact seagate. Put in external usb drive mount and format from another computer.
Jul 24, 2012 | Seagate Momentus 4200.2 (ST9808210A) 80 GB...
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
How to I reallocate my 500 gb external hard drive so I have more space for my laptop - I have 250+GB space avilable for my destop but I am getting "disk full" for the laptop.
you should be able to connect the external hard drive to your laptop and the drive should show up under my computer. Then just drag and drop or cut and paste any files you want to move to the external hard drive.
hope this helps.
May 21, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have a Seagate Free Agent Pro GB HD. Recently purchased a a new computer and cannot locate drivers for this equipment, can you recommend a site where I can download?
Hi and Welcome to Fixya,
Here is the download site from Seagate
Please check that link and then download the driver for your device.
Jan 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Question about transferring files from computer hard drive.
Is your other drive an external or an internal drive??? If external then attach it to the USB port and see it as an additional drive in My Computer. Then you can use it as any other drive.
If an internal drive then you will have to purchase an adapter that can take this drive and get connected to the PC/laptop to through the USB port. Again visible on My Computer as additional drive and can be used such.
Dec 17, 2009 | Averatec 6100 Notebook
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Seagate 250GB FreeAgent USB 2.0 Ext Hard Drive with laptop
Whether your computer is a laptop or desktop does not inherently decide if the drive will work or not. If it can't see the connection, there must be another problem with the drive. I would suggest reporting what you have done to try and make it work and anything you notice out of the ordinary (how lights on the drive are acting, noises the drive is making, alerts you see when you plug it into your laptop, etc). That will allow us to better help you find a solution to the problem.
Feb 19, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Feb 10, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate Momentus 5400.3 Hard Drive Logo
301 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
