Question about Saws
Einhell cordless screwdriver
How do I change the screw tool - gone to use and husband left different tool in end and do not know how to get out and put bit in I want. Do I turn something to release?
thaurfen
  • 623 Answers
SOURCE: black & decker pivot driver cordless
1.drill hole
2.place rod and anchors
3.screw in
Posted on Aug 23, 2008
  • 1214 Answers
SOURCE: how to change drill bit
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Posted on Jan 28, 2009
smjdragonfly
  • 79 Answers
SOURCE: how do you load screws in Dewalt DW272WT VSR
You definitely need a hex-bottomed screwdriver bit. Please rate me
Posted on Jun 18, 2009
  • 29 Answers
SOURCE: Hitachi Quick Release Drill problem
put a box end wrench 7/16 or a 3/8 over the bit. put the bit in a vise. Lightly tap the wrench with a hammer while holding the relase sleeve back. usually need 2 people. 1 to hold the drill and the sleeve and 1 to hold the wrench and hammer. try a little tranny fluid or wd40 in the chuck. don't use the painted bits. use onle the chrome ones
Posted on Jun 21, 2009
  • 12 Answers
SOURCE: the bit is stuck and i can't change it
try clamping the bit in a vice and rotate sharply left and right while pulling on it, cam
Posted on Jul 14, 2009
My einhell cordless screwdriver stopped working suddenly after it was fully charged....HELP
return item where you bought it...get another or money back
May 08, 2014 | Saws
Recumbant bike slips while peddling
http://www.youtube.com/watch?v=mVJxs7ALxDM&feature=related
Loose Pedals 1
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm.
Oct 30, 2011 | Nordic Track NordicTrack Treadmill, A2550
I don't have a Brio triangular screwdriver
The battery is easy to replace. The screw is located in the black "smokestack" and will require a small size phillips-head screwdriver to unscrew. The rest is easy--lift up on the black smokestack (I usually leave the screw in place), and the two AA batteries are located end-to-end in the body.
Oct 24, 2009 | Brio Mighty Red Locomotive
What is the difference between a slotted round and square screwdriver?
A slot screwdriver may be used for screws with a recessed single groove that stretches across the head of a screw. A square ended screwdriver was invented in Canada by a man named Robertson. These types of screwdrivers are named after him and come in different sizes from 0, 1, 2, 3 and have different coloured handles, yellow, green, red and black to mark the sizes. Number 2 (red) is the most common for wood screws. Square drivers make better contact then slotted ones and don't strip the head as quickly.
Sep 30, 2009 | K-D Tools 1/4" x 4" Square Blade Slotted...
My brush is no longer working on my bissell healthy home vac. when i try to turn it on it makes a high pitched squealing sound. I'm pretty sure it needs a new belt but my husband is having trouble getting...
According to Bissel, they should be standard phillips screws. Nowever - things change.
This is a general guide from Bissel for belt change -
BELT CHANGE _ CLICK HERE
Check your model number on that site for exact details.
If the screws are Torx (star) or other security screws, tool bits are available from Screwfix -
SECURITY SCREW BITS
That fit standard loose-bit screwdrivers.
Hope that solves your problem.
Thank you.
Sep 22, 2009 | Bissell Healthy Home HEPA Bagless Upright...
How to change the chuck on a draper red line 18v cordless drill
The screw you are trying to remove is left hand thread. You must turn is clockwise to remove it.
Hope this helps
Apr 15, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
How do I replace battery in Black and Decker cordless screwdriver
Just to clarify you have a model number 9076 and I would assume type 1. If so there are screws holding the 2 halves together that would have to be removed the batterys are in the lower section of tool. They are about 8.60. I would recommend going to DeWaltservicenet.com and typing in your model number to look at a product explosion before attempting this repair. Keep in mind that I saw that quite a few of the parts are no longer available so it might be time to retire this one.
Jan 01, 2009 | Black & Decker 9072CTN 2.4V Cordless...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
