Question about Sony KV-TG21M61 21" TV
Circuit diagram screen side
Where is the blower relay on my toyota carolla 2005 and if its faulty can that make the fan to be on with key off
Yes, it is possible, note the diagram, manual hvac. If you pull fuse for load side of relay, it should kill the blower motor. Then you have control side of relay, left side in diagram, has to have voltage and ground. The voltage is only hot with key on. So if that side has voltage with key off, either something wrong with ignition switch or the circuit is shorted to voltage. See the line with arrow head, when relay is energized that line moves to other terminal and the circuit carries voltage to blower motor.
Oct 22, 2016 | 2005 Toyota Corolla
Diagram 1998 Chevy metro lsi fuse box
Debbie, there are 3 fuse clusters. 2 under the hood on the drivers side and one under the drivers side dash board tucked up high on the left. Links to diagram below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.autofuseboxdiagram.com/4877-1998-chevrolet-metro-3-cylinder-engine-fuse-box-diagram
1998 Chevrolet Metro 3 cylinder Engine Fuse Box Diagram Circuit Wiring...
fuse boxes
Feb 28, 2016 | Cars & Trucks
Need a circuit for a medion md30612
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given.
Sep 01, 2017 | Televison & Video
Staircase wiring circuit diagram for 2 way switch
Copy following link for wiring 3-way switches (where 2 switches control same lights)
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Each 3-way switch has 3 screws (plug green ground screw)
Two screws are 1 color usually brass, and other screw is different color usually dark.
The dark screw is common screw.
There are two basic wiring diagrams: Line-side/Load-side with neutral wire. And Line-side/Load-side without neutral wire.
Open link above and scroll down to see both wiring diagrams.
Nov 04, 2012 | Prime 10 Amp Circuit Breaker
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
Circuit diagram for WEstinghouse Virtuoso Side by Side Fridge
It helps us to help you if we have a model number to work with. I have a site called www.mymarcone.com that if I have a model number, I can look up virtually ANY appliance diagram. Please post on this again with a model number and I will do my best to help you.
Mar 30, 2008 | Refrigerators
Sony KV-TG21M61 21" TV Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
