How to reset lamp ours on panasonic pt vw430
How to reset lamp ouers
  • 19 Answers
SOURCE: reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Posted on Jul 01, 2008
SOURCE: Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Posted on May 03, 2009
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Posted on Jul 25, 2009
  • 32 Answers
SOURCE: How do I reset the Panasonic PT-40LC12 projection
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Posted on Jan 20, 2010
Testimonial: "Thank you so much for your help. Worked like a charm!"
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
Tip
Panasonic PT-61LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic PT-61LCX66 Television
Tip
Panasonic PT-56LCX66 Lamp Timer Reset Models No. PT-52LCX66 / PT-56LCX66 /...
I hope that helps.
on Apr 11, 2010 | Panasonic PT-56LCX66 56" HDTV
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
How do I reset the metter for a new lamp?
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 06, 2009 | Panasonic PT-52LCX66 Projection Television
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Last night, a message started appearing saying the lamp needed to be replaced on our Panasonic LCD TV. What is this and is it something we have to do? I think it's the Panasonic PT-AX200 LCD Projector, but...
the lamp is good for about 2000 hours. after this, the lamp may still work, but not as well or for very much longer. after you replace the lamp, you have to reset the lamp timer (in the menu settings).
Aug 10, 2009 | Panasonic PT-AX200 LCD Projector
Lamp reset
Pushing the - volume button on the tv and split above the play button at the same time for ten seconds or - volume on the tv and the split control button at the same time. The lamp reset message should come on.
Nov 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
