Question about Refrigerators
Refrigerator whirlpool wbm 501
I have a brand new WBM 501 and it does not work. The freezer gets cold but doesnt make ice) and the fridge does not work at all. Could you tell me if there is a control panel to set thermostat for the fridge?
    New Friend:
  • 46 Answers
Problem is defrost thermostat, defrost heating element or defrost timer and or low gas in the system. Remove the back panel in the freezer and look to see if the evaporator coils are frozen solid with ice. If so the problem is no defrost cycle. If no ice then the unit is low on gas and it has a leak. If the refrigerator is old... recycle it and go buy a new refrigerator from Whirlpool.
Posted on Feb 08, 2014
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
Whirlpool wbm 48
That is a short on gas problem but make sure that the fan is running and check the settings on the inside of the unit so that you can have a circulation around the whole unit. If all this is good then Check your warranty or get someone to check for a gas leak. Get fixed and charge it with the write amount of gas and your problem will be solved.
Good luck
Will
Jul 28, 2014 | Whirlpool Refrigerators
Whirlpool wbm 569/1
Did you give the Refrigerator 24 hours? Did you lay it on its side shortly before plugging it in? Does your wall outlet have power or maybe the circuit breaker is popped? Otherwise you probably need a replacement
Oct 22, 2013 | Refrigerators
I have a Whirlpool refrigerator Model WBM 35 ix that is about 5yr old . The problem i am having is with the freezer. (the frige area stays cold) Some times the freezer will work and freeze food but i...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Kitchen Ranges
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
Whirlpool wbm 39 fridge freezer. Has not been opened for a day or two and now trips the power supply every time you plug it in, it does this after about 1 min
TRY TO USE A DIFFERENT POWER SUPPLY. IF IT WORKS YOU GET AN OVERLOAD ON THE OTHER CIRCUIT.
IF IT DID THE SAMETHING THE UNIT HAS A SHORT
YOU NEED TO DO AN EYE AND MANUAL CHECK.
UNPLUG IT GO TO TH MOTOR COMPARMENT TURN EVRYTHING MANUALY TO SEE IF THEY TURN NORMALY . IF ANYTHING JAMB THAT SHOULD BE THE PROBLEM
Oct 24, 2010 | Refrigerators
TRY TO USE A DIFFERENT POWER SUPPY. IF ITY WORKS. THERE IS AN OVERLOAD IN THAT CIRCUIT NEED TO LOOK FOR.
IF IT DID THE SAME. THER IS A SHORT ON THE SYSTEM.
UNPUG IT GO TO THE COMPRESSOR COMPARTEMENT
DO AN EYES AND MANUAL CHECK. TURN EVERY SINGLE THING THAT SHOUD BE TURN FREELLY BY HAND.
IF YOU SEE ANYONE OF THEM JAMB THAT SHOULD BE THE PROBLEM
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Jan 21, 2010 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
