Question about Yamaha RXV367 Receiver
My Yamaha RXV367 Receiver won't turn on after firmware update
My rx-v367 turns on then shuts off immediately
YAMAHA RX V367 HTR 3063 SM Service Manual free download schematics eeprom...
bad or leaking capacitors or shorting somewhere first disconnect power amplifier a variable powersupply variac it can be very helpfull
Jan 25, 2014 | Yamaha RXV367 Receiver
Tuning problem
There should be a switch on the rear of the receiver to select channel spacing but you may not be able to select spacing that meets Turkish standards.
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
Receiver doesn't power up after the update.
Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
Oct 18, 2012 | Yamaha RX-V473 A/V Receiver Black
I have a Yamaha Rx-v367. I have the Wii console connected as shown on page 17 in the pitiful excuse for a manual that comes with this receiver; composite video (blue, red,green) hooked up to AV1 and the...
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v367_black__u/?mode=model
Yamaha has posted specific support for nintendo Wii as well as a couple firmware updates. If you still need some help, post a comment ant I can help you further.
Jan 18, 2011 | Yamaha RXV367 Receiver
I can't get a sound from my yamaha rx-v367. my tv is lg le5310
Last update: 05/02/2008
Connect the audio outputs jacks from the TV to any available audio input terminals on the Yamaha receiver, other than the phono input. You can use any analog audio Left (White) and Right (Red) inputs on your receiver such as the DTV/CBL, SAT or VCR input. There are no special settings needed on the receiver, other than selecting the correct input. There may be some settings that will need to be changed on the TV. Consult the TV ownersEmanual for setting up the TV to output audio to an external source. If youre TV has a digital output (Optical or Coaxial) it can also be run to one of the digital inputs on the Yamaha receiver, such as DTV/CBL or DVD. There may be some settings that will need to be changed on your TV. As always, consult the TV ownersEmanual for setting up the TV to output digital audio to an external source.
NOTE: When the source of the audio signal is coming from an HDMI device connected to the TV, the TV may not output in 5.1 surround sound.
Jan 01, 2011 | Yamaha RXV367 Receiver
Why does my Yamaha receiver control the power for all my components - when I turn off the receiver all my components turn off (or won't turn on when the receiver is off)?
This will happen when connection setup is through HDMI cables between all components. Turning off one thing will turn off all connected things in that setup.
This is not problem, in fact it is feature because HDMI cable has control signals as well including video and audio signals.
Hope these info will help you.
Let me know if connection setup is different or I missed any thing.
Thanks.
Dec 29, 2010 | Yamaha RXV367 Receiver
Yamaha RXV367 Receiver Logo
49 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
