Hi I have Komatsu PC60 (early ninties I think) .The slew just stopped working. It has never had a lot of power since I have owned it. At the same time the automatic reve increase stopped working also. By this I mean you put the throttle in high postion & untill you operate anything the revs remain low (hope that makes sense) Can anyone tell me what may have gone wrong please. Thanks
SOURCE: JENSEN XA 184 AMPLIFIER
Looking at amp pin no.1 (top row on left, closest to the GND terminal) from left to right
{ output } { input }
[FL-] [FR-] [RL-] [RR-] [FL-] [FR-] [RL-] [RR-]
[FL+][FR+][RL+][RR+][FL+][FR+]{RL+][RR+]
Posted on Nov 20, 2007
flapjack937
  • 129 Answers
SOURCE: rev counter
The revs were reset wrong, get them re adjusted. Go back to same garage and ask for it to be done free, as it was done wrong first time.
Posted on Jul 18, 2008
SOURCE: Engine Reving excessively
1. Engine on-dissconect the power lead to the [idle speed control valve] located on top of the engine.
2. turn engine off-
3. turn engine on, you may need to use throttle to start and to reach and hold tick over speed. Once tick over is achieved, re-connect the power lead the idle speed control valve.
You should now have normal tick over speed!
Posted on Sep 22, 2008
  • 3567 Answers
SOURCE: Clutch problems Suzuki RM125
Do a gearbox oil change. Then do another one 50 miles later. This should flush out the dirt and grit currently in the gearbox. You may want to invest in a new clutch cable also. 10w40 motor oil.
Posted on Apr 09, 2009
  • 33 Answers
SOURCE: engine revs remain high or increase when braking
Have you tried checking your throttle positioning sensor. Possible vacuum leak or check for carbon build up in the throttle body not letting the throttle valve shut all the way.
Posted on Jul 24, 2009
Hi i have a bobcat 355 g 2005 model it makes a clunking sound when slewing and the slew brake fails to work some times any hints guys
indicates that the sprocket teeth are damaged/ worn and it is mismatching
could be from failing slew bearings
check brake adjustment and pad lining thickness
best get a bobcat service center to check it out
Jun 20, 2017 | The Optics
Early childhood education?
There are plenty of places that you can work in the early childhood education field that have health benefits and pay. If you truly have the heart for early childhood education, you should go for it, as there are not many people that truly have the heart for it.
Some places that you can work with benefits:
Public school system-pre-kindergarten teacher
County government-social worker for preschoolers
Self employed-home daycare provider, buy your own health insurance
Pediatrician-work with young children and make a lot of money
Daycare center-many provide health benefits
Good luck to you!
Jan 04, 2017 | Preschool
Komatsu zenoah
www.komatsu.com or
conequipmentparts.com/komatsu-parts
May 20, 2014 | Garden
Lost the slew on a kamatsu pc40
Check that the key in the drive gear is not sheared in half. check that by trying to slew and see if the drive motor is working. The hydraulic motor may be seized up
Mar 19, 2013 | Joal 1/32 Komatsu PC 450 LC-6 Excavator
OverHeating PC60-6 1995 Excavator Issues
Save your hair, Silvano, it's not worth it.
When you did the head gasket, did you check the head for cracks? Sounds like the problem does originate in the engine. That's where the temp sensor is located. That's where it would get hot first.You might want to have the head magnafluxed to check for hairline cracks. Good luck.
Mar 30, 2012 | Cars & Trucks
Roland PC60 - flashing lights - why?
This happens occasionally with myself if I am printing a large number of labels which is taking a while and decide to cut off some already printed labels from a previous job off from the roll before the current label job has finished. It then feeds the roll back past the edge sensor on the front, gets confused and flashes the lights. I don't unfortunately know how or if the printer can be restarted from this point. If I do i'll post here or if you manage to fix it please let me know. It has something to do with me cutting the roll and the roll passing the front edge sensor.
Jan 26, 2010 | Office Equipment & Supplies
My volvo ecr38 does not stop slewing when lever is stopped, it carries on for approx 1 metre before stopping, any ideas ?
Maybe the springs and discs in the slew brake are worn or the slew spool is not coming to neutral when you release the handle,check to see its dumping servo pressure.
Dec 03, 2009 | Garden
Says transfer belt and imagining unit are bad. Still working. Are these things I can replace or are these warnings early just to get me to buy parts?
Transfer belt is not an essential replace. But a bad imaging unit may cause heating issues, lost toner to fill your printer with dust interfering with sensors, and a slew of other issues left unchecked. That said, you could run for a while before either became a serious threat.
It's a lot like running your car without oil...you can do it, but when it goes it will be gone!
Nov 13, 2009 | Samsung CLP-510 Laser Printer
I have a celestron nexstar 5 the begins to move on it own
Many times a bad cable will cause this. Also low batteries can cause this.
Contact Celestron and order a new cable. Use an external 12 volt power pack.
http://www.celestron.com/c3/page.php?PageID=37
Nov 05, 2009 | Celestron NexStar 5 SE (300 x 44.45mm)...
Roland pc 60 color camm
look on www.rolanddg.co.uk and they might just help. i have just got a pc60 and the test print/cut is'nt working so i'm not a happy bunney. Andy @ YesIDoOwnTheRoad.com
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
