Not getting power
I am replacing my car stereo in my saturn, and am not getting any power to the new stereo. We hooked it up to the battery and it works there but not when we plug it into the harness. The old stereo works but new ones doesn't. We checked the fuses, and the radio one blew, so we replaced it and it blew again so (both times after we plugged in OLD radio)so we put in a 15 instead of a 10. Not sure what else it could be???? help please......
  • 71 Answers
SOURCE: replacing radio in a 1996 toyota corolla
could you give me more info plz
Posted on Jul 30, 2008
  • 39 Answers
SOURCE: problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Posted on Nov 24, 2008
  • 5 Answers
SOURCE: Hi on my hp psc2110
most likely some problem with the cartridge itself.
if you are using "aftermarket" cartridges, that is usually why the printer doesnt full recognise it...if using a real hp cartridge, there might be a problem with the little circuit board (that is under the tape strip when new)...try returning it to the store where you bought it and asking for a replacement.
Posted on Jan 03, 2009
SOURCE: Epson Stylus CS5800F Printer will not power on. Plugged into known working outlet, but no luck.
I had that same problem with my CX5800F. I tried it in several working outlets and shut down/started up many times. Tech support couldn't figure it out so they had me sent it back for a replacement. Several days later, before I packaged it up for shipment, I decided to test it out one more time, and it powered on! I sent for a replacement anyways. Since it's still under the 1-warranty, I'd suggest sending it back for a new one if all else fails. Good luck!
Posted on Jan 18, 2009
  • 110 Answers
SOURCE: replacing a stereo into a 2005 Saturn Ion
not sure if your still looking for a solution or not but here you go. that orange and white wire is normally the wire that controls the dimmer within the stereo. when you dim the dash light the factory radio lights dim and that wire is suppose to make the new radio do that also. in my past i have found that only about 30 percent of the aftermarket radios actually do that when hooked up. give this a try and let me know. good luck
Posted on Feb 28, 2009
Sorry i forgot to say i have a 1996 saturn so i need the stereo wiring color code of stock stereo to put in my new stereo
Buy a wiring kit from wal-mart or stereo shop. It will allow you to plug into stock wiring without cutting anything, and have instructions for hooking up your new system. Cheap and easy, plus you can go back to stock should you ever sell the car.
Jan 28, 2015 | Saturn Cars & Trucks
I have a 1998 saturn and i put in a new stereo all wires are connected and working fine but the power antennae isnt hooked up neither is the orange illumination wire when i hooked the illumination wire to...
Hi, not sure what model you have, but you can get the factory wire colors here: http://www.modifiedlife.com/request-a-saturn-car-radio-stereo-wiring-diagram/
page down to select your model.
It sounds like you tapped into the brake light wire rather than the illumination wire. Also, there should be an antenna wire in the car if you have a retractable antenna. Did you purchase a GM connector with the new steroe to wire it in?
Mar 12, 2011 | Car Audio & Video
97 Saturn sl. battery went dead,,replaced
Did you check the alternator? if it is faulty the car will drain all the power from the battery until it goes flat
Jul 09, 2010 | 1997 Saturn SL
How do I unlock my 2000 Saturn SL1 car stereo?
Visit http://www.radio-code.com/index.htm
Good luck.
Dec 15, 2009 | 2000 Saturn SL
Car will not start after installing CD player into a 1999 Saturn!
Check your Ignition 1 & ignition 3 fuses in the inside fuse block,also check the body fuse 10amp in the inside fuse block.Keyless entry should take back off once you found the blown fuse.hope this helps
May 26, 2009 | 1999 Saturn SL
When I replaced the stereo in my daughter's car I lost power to the Ignition. I still have dash lights. But no power at the stereo and the car will not turn over. Also the keyless entry stoped working. How...
car stereo that come with car is program to car pcm security system.when you change stereo.the pcm dont recognize the new stereo.the pcm goes into anti theft mode it disable ignition.system.
May 17, 2009 | 1999 Saturn SL
Replacing a stereo into a 2005 Saturn Ion
Jan 04, 2009 | iLO XM-MP3-CD Car Stereo
1998 Saturn will not start after new stereo installed
it means the wiring is wrong check and look fo the ignition cable and make sur it's properly secure see the wiring is all a big maze in thesecars u have to make sure everything is wired correctly the battery wire as well
Dec 27, 2008 | 1998 Saturn SL
Car stereo help
There are some tests you can perform for checking the stereo. Yes, you are right, there is a yellow and red wire. Yellow constant power, red is switched throught the ignition. During the installation, you may have blown a fuse. A bigger fuse is not needed, stick with the same size if you find a bad fuse. Hook the red and yellow wire together for TESTING PURPOSES to one or the other of the hot wires in the vehicle. This will also test to see if you have a bad fuse. If the stereo powers up in one or the other power connections in the car and works, you have a blown fuse. I have seen some fuses be located under the hood of the car near the car battery. Hope this helps, Bob
Oct 29, 2008 | Car Audio & Video
No illumination and no sound in my Saturn LS2
I suspect you have an auxiliary factory amplifier. Contact this company at the link for installation information.
Shop Car Stereos
Apr 04, 2017 | Aiwa CDC-MP3 CD Player
22 people viewed this question
jasbo
jasbo
