Question about Electrical Supplies
The onan marquis gold 5500 runs great but it leaves smell of gas vapor In the main bedroom?
  • 384 Answers
SOURCE: Generator runs fine turn on one breaker and shuts down
it sounds like a short on that breaker
Posted on May 18, 2009
SOURCE: 5500 marquie gold startes run for a few nim thin
shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Posted on Jul 23, 2009
  • 905 Answers
SOURCE: Onan Marquis Gold 5500 on
A1 controller could be suspect, http://www.flightsystems.com/ can get you going with board cheaper than OEM, last longer too.
Does the generator shut down immediately after you let go of the start switch? If so, you are looking at oil pressure / level fault. Check oil level and sending unit. If generator continues to run for a few seconds and then shuts down, that is due to no or low AC voltage being produced and shutdown occurs. Shutdown for AC usually indicates an open winding or damaged voltage regulator.
Posted on Aug 25, 2009
  • 6 Answers
SOURCE: I have an onan 5500 gas generator that wont start
What is the model? Chances are the carb needs cleaning or replaced.
Posted on Sep 28, 2009
  • 16 Answers
SOURCE: Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
Posted on Jan 15, 2010
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
WHAT IS ERROR/FAULT CODE 37 ON A ONAN 5500 MARQUE GOLD GENERATOR ?
Code 37 is a bad set configuration, that means engine cranking speed and generator output aren't happy with each other..
Sep 30, 2014 | Onan Marquis Gold RV Generator 5500 Gas
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Jun 23, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan marquis gold gas generator 5500 stops running after 5 minutes
Check fuel pump pressure, how long has it sat. What load is on after it stops?
Jun 10, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Doesnt want to start, when it does it runs rough then dies, several tries and it will run rough and eventually smooth out and run ok, also intermittant loud clicking sound,think its the fuel pump
sounds like u need a new fuel pump when u first start up fuel has seaped back to tank only when u crank it brings fuel back up then the speed keeps fuel ok , replce fuel pump shud b ok then.
Oct 09, 2013 | Onan Marquis Gold Quiet Gas Generator 5500...
Free Service Manuals
What is the question? You want a free service manual?
May 07, 2013 | Onan Marquis Gold Quiet Gas Generator 5500...
Il s'allume et s'eteint quelques secondes apres
I can help if you describe the issue in English please :(
Apr 02, 2013 | Onan Marquis Gold Generator Lp Vapor 5500...
Jul 23, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
48 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
