Question about Sharp Mx-M354n Mfp
Ma machine affiche le code:h5-01que faire? - Sharp Mx-M354n Mfp
3 Suggested Answers
  • 990 Answers
SOURCE: error l4 02 in sharp ar5132
Dear sir;the error code you ask about for sharp copier, it means drum motor problem, why don't give them a try to reset before go to replace it, the procedure is
1, press "clear", "pause", "0", "pause"key
2, press 14 then press start.
Have anymore question, please let me know,
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
  • 22 Answers
SOURCE: MON PHOTOCOPIEUR AFFICHE LE CODE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Posted on Feb 10, 2011
Ma machine canon I-SENSYS MF 4550d , s affiche erreur E301-001,que veut dire ce code , et qu est- ce qu il faut faire?
google translate
My machine gun I-SENSYS MF4550d, appears E301-001 error, what does this code, and that is, that it be done?
Jun 10, 2016 | Canon Office Equipment & Supplies
Canon mf4412 error code e301-0001
ma machine affiche le code e301-0001 lors de l'impression, la marque de la machine c'est canon i sensys mf 4410
May 29, 2013 | Office Equipment & Supplies
Mon tapis roulant sportcraft tx390 ,a commencer a sentir le brule 3 jour apret que jais du ajuste mon tapis car il avais tendense a bouge sur la droite et frote donc jais fait un ajustement et cest...
bonjour, quand je fais partir mon tapis roulant il fonctionne pendant quelques seconde, ensuite le chiffre ( 3 ) s`affiche dans le coin gauche et il cesse de fonctionner, pourriez-vous m`aider? Merci
Apr 12, 2012 | Cars & Trucks
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
Hope this helps
Feb 09, 2011 | Sharp AR-M205 Copier
Bonjour ou se trouve le reste sur ce modele?? j'ai DEG de programme dessus et je ne suis pas capable de l'enlever. merci
écoute, ne te fâche pas : je ne comprends pas le sens de ta question et je devrais m'abstenir de te venir en aide, craignant d'interpréter incorrectement ton problème (et ce n'est pas ma maîtrise de la langue de Molière qui est en faute!!) Mais je vais quand même essayer de t'aider.
L'indicateur DEG que tu sembles vouloir éradiquer est parfaitement inoffensif. It est affiché sur l'écran pour te rappeler que l'unité d'angle est le degré. Cela signifie que tout argument que tu fournis à une fonction trigonométrique (sinus, cosinus, tangente, cotangente) est interprété comme une valeur en degrés. Donc si tu calcules sin(Pi) ne t'attends pas à obtenir 0 mais le sinus de 3,14.. degrés.
De même, toute valeur retournée par une fonction trigonométrique inverse ( arc sinus, arc cosinus, arc tangente, arc cotangente) sera en degrés.
Si tu changes l'unité d'angle de degré à radian, l'indicateur RAD sera affiché quelque part sur l'écran. Donc je te suggère de ne pas t'acharner à faire disparaître cet indicateur: Il ne fait que te monter quell unité d'angle tes calculs utilisent. C'est plutôt commode, ne trouves-tu pas?
Maintenant, si tu veux préciser ce qu'est ce reste que tu cherches, peut-être pourrais-je t'aider? Tu n'as qu'à faire un commentaire et je verrai ce que je peux faire.
Jan 17, 2010 | Casio FX-250HC Calculator
?AINTENANCE
Salut, normalement la maintenance veut dire ceci : remplacer le Fuser, et les kits de petits rouleaux pour les bacs (Manual feeder et le bac 2, 3 etc) et le "registration roller". Toutes les pièces de maintenance sont faciles à changer normalement. Il faut contacter le fabriquant (ou votre vendeur de pièces informatiques) et commander le kit de maintenance pour le modèle de votre imprimante. Si ils sont gentils, ils vont inclure la marche à suivre dans la boîte pour comment faire chacune des opérations. Bonne chance!
Jun 09, 2009 | IBM Infoprint 1422 Laser Printer
Ma photocopieuse affiche H4
salut ! le code H4 c'est une erreur qui vient du fuser ( la ou le papier passe et les rouleaux deviennent chaud)
Il faudrait checker la lampe de chauffage et voir si elle est intacte,
la deuxieme possibilite est le fuse de prevention de haute chaleur, (thermofuse)
L'une des deux est votre probleme. Salut, et Bonne Anne.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Solution ?  ,mon erreur E000019-0000
j'ai un problème avec ma IR 3300 il affiche un code E 248-002, que faire? aide moi SVP!!
May 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Sharp Mx-M354n Mfp Logo
89 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
