Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Cannot copy from adf - Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Copy off glass copy is good. copy from ADF copy is blurry
The problem is either dirty glass for the ADF which you can clean, or the ADF cannot feed the paper you are trying to scan through accurately. Most smaller all in one printers use the same scanner element for both the ADF and flat glass scanning so the fact that glass scanning is fine points to the two problems listed above.
Mar 29, 2011 | Office Equipment & Supplies
I have a HP 3390. When I make a copy form the ADF it has a vertical line down the copy. All is OK when I make a copy form the glass or receive a fax.
you need to clean the rollers of adf and the glass strip that you will find when you open the adf cover.
and then try to copy
Oct 21, 2009 | HP LaserJet 3390 All-In-One Printer
Having problem copying from ADF
On this model, the Intensity needs to be set to 'Manual' to make copies from the ADF.
1. Press the 'Settings' button repeatedly until 'Intensity' is displayed
2. Press the left or right arrow until 'Manual Adjust' is displayed, then press the 'OK' button
3. Press the left button to decrease the intensity, or the right button to increase the intensity, then press the 'OK' button
4. Press the 'Back' button repeatedly to return to the Copy standby mode
To return to 'Auto Adjust', follow the above instructions selecting 'Auto Adjust' at step 2, and skipping step 3
Aug 28, 2009 | Canon PIXMA MX310 All-In-One Printer
When I use the adf to copy something there are always two lines on one side of the paper (to mark the copy). How can I change the setting for this problem. It does not occur when not using the adf. Thank...
Hi;
If you are only getting the lines when using the ADF , but not when placing the document on the glass then there is some type of debris on the scan glass.
This is a small strip of glass that is independent of the copy glass. This glass should be to the left or right of the copy glass. Just glean this well with alcohol or windex and try copying again from the ADF and see if the problem is gone.
Good Luck
Andrew
Jun 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How can I set up the ADF to copy on dell printer 3115?
It would help to know what kind of machine this is. But check to make sure the cable from the ADF is plugged into the back of the copier. If it is not. Turn off the machine, unplug it from the wall, then plug the ADF into the machine. After that is complete plug the machine back in and power up.
Jan 27, 2009 | Office Equipment & Supplies
Black lines across copies
try the drum, replace and make a copy
Aug 18, 2008 | Sharp AL 1631 Copier
AR-206 copying problem / paper comes out slanted
There could be somthing in you ADF that is keeping the copy from going in properly. Your tires could need cleaning or there could be something going on with a component in the ADF.
Sould have a technician inspect the ADF to see if it needs cleaning or parts.
May 30, 2008 | Sharp AR-207 Copier
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
13 people viewed this question
old marine
old marine
