Question about Bose 321GS Series II System
No sound when connecting with a fiber optic.
I have an HD cable box & a PS3 both connected to my new samsung LED DLP via HDMI.  the fiber optic out in the samsung is connected to the fiber optic in, on the bose 321gsII.  Bose unit recognizes the fiber optic and reads PCM 2.0 when on the correct soure.  optical cable is activated in the media center.  have tired fiber optic port with all components, same result.  have tried multiple fiber optic cables one of which is brand new (and with the exception of the brand new one have worked with other systems).  what are the bose tech guy and me missing?  i couldnt have gotten two deffective units.
  • toolucky523 Oct 26, 2007
    forgot to mention in post above that i had this same problem and returned the unit for a new one.  hence the last sentence, 'i couldnt have gotten two deffective units.'  also this doesnt appear to be a common problem as i have browsed other tech forums looking for someone else who has this problem.
  • jimedington
    jimedington Jan 16, 2012
    i had the same issue. i messed with the samsung tv's functions and eventually got it working. the issue wasn't with the a/v receiver, it was the tv's settings.
  • 70 Answers
Have you tried a new cable?
Posted on Oct 27, 2007
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
I connected a sony playstation 3 and there is no sound while playing games. The video works and I can play the game, but there is no sound. I returned the playstation 3 thinking it was the console but the...
Adjust the audio output on your playstation and the television depending upon how you're connecting it to the television for picture and sound.
For an hdmi cable between the television and the PS3 only then adjust the audio ouput to hdmi on the PS3.
You do not need to connect anything else between the television and the PS3 besides an hdmi cable.
If you are using the colored plug type component or composite cables then it is av.
If you are connecting with a fiber optic cable to a surround sound system then it is set to optical.
Depending on what television you are using you would also have to change the Playstation to 48khz/96khz
Jan 09, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
Nov 06, 2010 | LG Televison & Video
I am trying to connect my ps3 via hdmi, digital cable box via fiber and my tv via hdmi. I cannot get the picture to display on the tv. Any suggestions?
I connected a fiber optic cable from the cable box to the receiver and connected an hdmi cable from the cable box to the tv.
Sep 30, 2009 | Samsung HT-TZ512T Theater System with...
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Jan 02, 2008 | Sony STR-DG510 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
I am pretty sure you need to have an Optical cable running from Your PS3 to your sound system...if you have one...
So basically you will have a HDMI cable running from your PS3 into your TV, another HDMI cable running from your TV into your sound system, then an optical cable running from the PS3 to the Sound system. I sadly own a HDDVD sound system but the optical cable tells it to accept the Blu Ray content.....
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Bose 321GS Series II System Logo
904 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
