Question about Daewoo DWD M1031
Stopped working no power to machine - Daewoo DWD M1031
Dishwashers wont stop.
By unplugging the machine, and temporarily stopping the drain from operating, you have diagnosed that the issue is electrical and not mechanical. If it were a mechanical issue (something stuck in the drain, thus keeping it open) it would continue to do so, even when the power is disconnected. It sounds as though you may have an issue with your timer, which tells it when to advance to each cycle. It depends on your make/model of machine. I've worked on some machines that have a cam style, and if the notches are damaged, it will not advance properly.
Mar 08, 2014 | Electrolux Dishwashers
Bizhub copy machine start button blinking
power off the machine using main power switch not the control panel switch
Feb 06, 2014 | Konica Minolta Bizhub 362 Copier
Machine stop running
Make sure all power connections are in place, to outlet and to machine. Make sure power switch in ON.
Check outlet with working lamp to ensure power is coming to that outlet; check panel box to make sure power is coming to that outlet.
Aug 27, 2013 | Singer 2259 Sewing Machine
The machine stopped suddenly while it was in operation, i found the fuse in the power cable burnt, i replace the cable and tried to operate it again it worked for less than one sencond and it stopped...
Dear Sir:
You have a Short Circuit:
The short circuit only you can eliminate by usin VOM,
a) Isolate the power cable b) The main motor c) The power supply d) The main motor board e) The transformer.
You can also view my personal TIPS for helps.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Mar 08, 2012 | Nautilus T516 Treadmill
Why does my new Singer cg-500 stop working, then start for a little bit and stop again?
Probably thread wrapped around something....takeup crank, motor pully...if you can get inside to have a look great, if not, find someone who can.
Oct 25, 2011 | Singer CG500 Mechanical Sewing Machine
Washer full of clothes and water and stopped- how to reset?
According to my experince let the machine stop and complete shut power and try after 10 minutes
Oct 03, 2009 | Maytag PAV2300 Top Load Washer
Do not know how to work power washer
Dear Carrie688,
I cannot for sure understand your problem. You say, you do not know how to WORK power washer. Does WORK mean FIX...or USE???? I will assume that you wish to know how to use it.
First without water connected and without gun connected...switch on the machine. If it turns, then this means the electric motor is OK. Now connect the hose and gun. Connect water supply. Now always start the machine with gun open. This will help to remove air from system. When pressure builts up, close gun, and machine must stop instantly. If machine does not stop, open the gun again and switch off the machine. If the machine continues working when the the gun is closed, this will result in a lot of damage. I do not know what model you have, because also there are old models that when gun is closed, the machine keeps running. I assume your model is recent. So the machine will stop when gun is closed. Now when finished, switch off machine and electricity. And most important release pressure from gun. Do not store machine with pressure still in it. This will damage machine and it is not safe.
Now if you have detergent, this can only work on low pressure. There are bigger machines that detergent works on high pressure. But the normal system is that detergent works on low pressure. Also before storing, pass fresh water to remove all detergent from pump of machine. Never store a machine with detergent in its system.
Regards,
Fulltech.
May 13, 2009 | Karcher K2.26 Electric Power Washer
Our Hoover HD98E Dishwasher stopped working properly today. After a while the machine stops during the power spray cycle and just buzzes as though the pump is powered but not spraying. Is this the pressure...
its possible that your timer has a bad contack at this spot the machine stops but the drain valves open try advancing the timer one notch to see if it will work if yes relace the timer thanks from gilles
Mar 14, 2009 | Hoover 24 in. DT999 Free-Standing...
Machine off balace during washing then stopped working
could be either interface control(pushbuttons and knob) or machine control (gray plastic box)
Jun 01, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Daewoo DWD M1031 Logo
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
