Question about Denon DRA-275R
Need to know how to hook up my denon receiver
Need to know step by step where to connect each jack and speaker wire please
SOURCE: how to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Posted on Jun 28, 2007
SOURCE: Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
Posted on Aug 06, 2008
SOURCE: Denon 1508
This should resolve your propblem... taken from the Denon USA FAQ...
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.")
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Posted on Sep 22, 2008
SOURCE: audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Posted on Jan 11, 2009
How do I reconnect the two small speakers to my system if they have been cut off from the actual speakers?
If you need to connect new male connectors to the wire ends you can get them from any good electrical shop! Some are solder-less connections or if you are handy with a soldering iron you can do a proper job on it!
Dec 31, 2014 | GPX Hm3817dtblk Home Music Hi-fi System -...
How do you hook up a amp with a factory radio.. a 2002 impala
1- you need to provide a fused power wire from battery to amp
2- provide a ground wire from amp to car body or frame (be sure to clean off paint if connected to body)
3- connect your remote wire to your fuse box (16 to 22 gauge wire will be fine)
4- connect a line output converter which will allow you to use rca jacks (one side connects to the speaker wire in your car and the other to your rca jacks)
5- finish by connecting your speaker wires and rca jacks
if helpful please rate 4 thumbs up.
Jan 15, 2011 | 2002 Chevrolet Impala
I have 2 Alltech Lansing multimedia speakers w/subwoofer that I don't know how to hookup to my computer. I'm not savy at all when it comes to putting mechanical or electrical things together. Can somebody...
there are two wires out from the s/woofer, one goes to the power source, the other goes to the surround speakers. behind the s/woofer there should be an audio port/jack. a phono wire came with system connect one end to the jack and behind your system unit there should be two ports just like the ones behind the woofer, they both have icons beside them one icon is a headset while the other is a microphone, connect to the headset
Aug 08, 2010 | Computers & Internet
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How do i connect the speakers to my computer?
Step 1 Connect the green connector
from the subwoofer into the green jack on the computer
(the black connector is not used)
Step 2 Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3 Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4 Plug the AC plug into the wall outlet.
Step 5 Turn on the speaker set and adjust the volume accordingly.
Jan 22, 2010 | Harman Kardon HK695 Computer Speakers
I want to connect 2 speakers(left and right) to lcd.how can i?
Please follow the steps below:
Step 1: Connect the two RCA plugs on the Y adapter to the right and left Audio Out jacks on the back of the LCD TV.
Step 2: Insert the mini-plug on the cable attached to the right-channel PC speaker into the mini-plug jack on the Y adapter.
Step 3:Connect the mini-plug on the audio cable attached to the left-channel PC speaker to the mini-plug jack on the back of the right-channel speaker. This completes the PC speaker connections to each other and to the television. The TV sends an audio signal to the right PC speaker, which separates the signal and sends the left-channel stereo information to the other PC speaker.
Step 4:Connect the AC power plug to the back of the right-channel speaker and plug the other end into an electrical outlet.
Step 5:Switch on the speakers and the television to enjoy audio from both the TV's built-in speakers and the external pair of PC speakers.
Regards
BEADHZ
Dec 30, 2009 | LG 37LC7D 37 in. LCD HDTV
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Trying to reconnect a set of Harman Kardon candlestick computer speakers to a Dell Dimension E520 computer. I got three plugs and dell has 6 holes...what the heck goes where? Nothing I seem to try works...
Hi rjlevesque
For the speakers, you need only connect to the GREEN jack at the back of your computer. It's OK to leave the others blank.
Your two HK speakers will, with one wire, connect to each other and, w/ another wire (usually having a GREEN connector on the end), connect to the computer.
I'm not sure what the 3rd wire is unless it's (1) the power connector or (2) for connecting to a sub-woofer.
Does the speaker set include a sub-woofer? Or does it include a "surround sound" or 3rd speaker?
You can find pics & symbols (the symbols are helpful if your sound card jacks are not color-coded) for (3) of the most common audio connections HERE.
Usually the color of the connector on the wire is matched to the sound card jack w/ the same color. (green to green; pink to pink; blue to blue).
green = speakers
pink = mic
blue = line in
Make sure you are connecting to the active sound connectors - the ones you used b4 the HK speakers.
If you have "integrated audio" (audio that is built into the motherboard) and you have an audio expansion card installed on the computer as well, one may be disabled or not selected in your computer's audio configuration.
If that's the case (that you have two sets of audio jacks to choose from), try connecting the speaker wire from the HK speakers 1st to the green jack (or the jack marked w/ the symbol of a speaker) at the bottom of your computer. (There'll only audio jacks here if there is an audio expansion card installed on your computer.)
If that is the case, there'll be other (usually) colored jacks running horizontally next to the speakers jack.
If you still have no sound, connect the speaker wire to the GREEN jack that is (usually on Dells) up by your PS2 (round - one purple and one green) keyboard and mouse connectors (also at the back of your computer). The other jacks in that set (of audio jacks) will be situated vertical to one another and on the left-most side at the back of your computer.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Speaker out connection
I've got the same speaker system and have had trouble with the satellite speaker jacks causing them to cut in and out.
I disassembled the subwoofer to get at the jacks and repair them by resoldering some loose connections.
What exactly do you need as far as wiring descriptions?
Oct 17, 2007 | Altec Lansing ACS 48 Computer Speakers
Denon DRA-275R Logo
22 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
