Question about NorStar M7310 Corded Phone
Speed dial button says incoming call - NorStar M7310 Corded Phone
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Check the programming on all of your buttons by using Feature *0 and press any button to see what is programmed on that button. It sounds like something else is programmed on your speed dial button. To set a speed dial button press Feature *3 then the button you want to be speed dial. Press Feature 0 to program it.
Posted on Feb 09, 2014
Edit and existing speed dial
  1. Press the Function (FNC) button.
  2. Press the speed dial button you want to program.
  3. Dial the number.
  4. Press the Function (FNC) button to set the number.
  5. The message Speed Dial Set (SPD SET) displays, indicating that the speed dial button is now programmed.
NEC telephone user guide Thunderbird School of Global Management IT Help
Nov 10, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
Lexmark 9500 accepts and prints incoming wont send faxes...help
Check if you're using the correct dialing rules (if you need to dial 1 before the number). Also, try to decrease the transmission speed. To do that, on the control panel of your printer, press the down arrow until you reach Fax > Fax Setup > Dialing and Sending > Max Send Speed > set it to 19600.
Oct 30, 2012 | Lexmark Office Equipment & Supplies
When i calling my mobil atomacally dialing
abdul Rakib, it seems your green button is very sensitive, make sure you are not pressing twice and if problem persist post more comments for further help.
Jul 03, 2012 | Samsung star II duos GT-C6712
Is it possible to get caller ID for an incoming call if I have that number saved as a speed dial? If so, how do I get that. My phone is the Avaya IP Office 5410. Thanks
If the number matches the CID number, you should get the name as well. But here is the hard part.
IF your system requires you to dial an access code (say 9 to get an outside line) you may have that speed dial number saved as:
913125551212
If so, the incoming caller ID would have to match exactly, meaning CID would need to show 913125551212 in order for this to work.
BUT, caller id probably only shows 13125551212, and as such, wont work.
Jul 15, 2011 | Avaya 5400 Series 5410 Phone
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
How do I do a group fax with a M20i?
NOTE: The following solution applies only when the WorkCentre has the fax feature.
Speed Dial numbers must be set up before creating a Group Dial. If Speed Dial numbers have not been set up, See the Related Items below for additional information.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up] or [Down] arrow button until 'Fax Setup' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Group Dials' is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until 'New' is displayed, and then press the [Enter] button.
  5. Enter a Group Dial number between 1 and 200 using the numeric keypad, and then press the [Enter] button.
    NOTE: If a 'Location No. is Registered' message is displayed, the number has already been stored as a Group Dial. Enter a number that has not been stored, and then press the [Enter] button.
  6. Enter a Speed Dial number to be added to the Group Dial using the numeric keypad, and then press the [Enter] button. The name and fax telephone number stored for the specified Speed Dial number will be displayed.
    NOTE: If a 'Not Assigned Enter Again' message is displayed, the number has not been stored as a Speed Dial number. Enter a number that has been stored, and then press the [Enter] button.
  7. Press the [Enter] button. The Speed Dial number will be added to the Group Dial.
  8. Repeat steps 6 and 7 to add additional Speed Dial numbers to the Group Dial.
  9. After all required Speed Dial numbers have been added to the Group Dial, press the [Menu / Exit] button.
  10. If required, enter a name for the Group Dial using the corresponding buttons on the numeric keypad, and then press the [Enter] button. If a name is not required, press the [Enter] button.
  11. Press the [Stop] button to return to the Standby mode.
Feb 17, 2010 | Xerox WorkCentre M20i All-In-One Laser...
I'm trying to reset my speed dial numbers. I'm
I can think of only two reasons it doesn't work. What "Code" are you dialing? If you can't dial 600-699, then you are not at extension 10 or 11. If you're trying 80-99 you don't press FEATURE again.
Carl
Feb 25, 2009 | AT&T Partner 18 Phone (315805B)
Problem with speed dial buttons
to program a speed dial button - <feature> *1 - select button / enter speed dial number / quit....you may have to reprogram each button.
Feb 23, 2009 | NorStar M7324 Telephone
Keypad doesn't seems to work - seems locked - gets incoming calls
JOSE18
under tools there is a record option. erase all things that have been recorded. the button on the top screen on the right hand side allows you to record phone calls. You have probably been hitting it on accident and recording calls and such. Let me know if this works.
Nov 06, 2007 | Motorola Mobility RAZR V3
NorStar M7310 Corded Phone Logo
37 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
