Question about Keurig B31
Temperature Coffee is warm, it is not hot
  • 1,511 Answers
The temperature was set for optimum functionality at the factory and cannot be adjusted manually. It is important to have very hot water to get a quality brew; thus if the temperature is too low call 1-866-901-2739 for service.
Posted on Feb 07, 2014
Brews good hot coffee but warming plate has stopped heating! Are replacement elements readily available or could it be a fuse...??
The DCC-1200 has only one element, that both heats the water for brewing and keeps the carafe warm. If you're brewing coffee then the element is fine and the suspect part is the Thermistor. Another forum suggested this was a Vishnay NTCLG100E22245B, available from DigiKey (their part # BC2467), connected to the control board with thin yellow wires. The same forum suggested that this thermistor should test at 220K ohms at room temperature, dropping to 20K at about 220F.
Nov 17, 2015 | Cuisinart DCC-1200 Coffee Maker
Miele CVA4070 Coffee not hot enough
Here is what I would do;
1. Determine if you have noticed a change. i.e was the coffee hotter in the past or has it always been this temperature. If the cups are cold or the amount of water used for each cup is small then the resulting coffee will be cooler than if warm cups were used or if the amount of water used was larger. Also if the water is not hot enough you will not get a good Crema and coffee taste will not be correct.
2. Assuming the problem is not '1' above then the likely causes is the flow through water heater. This heater is used to heat water for coffee and also for the hot water. So if the hot water pipe is also not producing hot water then you know it's a problem with the flow through water heater or power control of this module. In addition to the actual heater there is a temperature limiter, temperature fuse and a temperature sensor. If some heating occurs then it is not the temperature fuse. But it could be a fault in the actual heater, the sensor or the limiter. These components are at mains voltage and thus identification of the fault and replacement of defective parts should ONLY be performed by a trained Miele technician. So if this is the problem its best to call Miele.
I hope this helps. Regards
Mar 10, 2014 | Miele CVA4070 Coffee Maker
Jura impressa j9 latte temperature
put in microwave , use hot boiling water , descale .
Dec 15, 2013 | Jura Impressa J9 One-Touch TFT Espresso...
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
Fetco cbs-51h coffee maker not heating hot enough. turned thermostat all wasy up. coffee luke warm.
It can be the Temperature sensing probe, heating element or a loose/burned wire connection.
Adjusting the brew temperature is not going to help
Jan 17, 2011 | Coffee Makers & Espresso Machines
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Primea ring hot milk
if you go in the menu there a temperature setting for that machine pierre
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Keurig B31 Logo
153 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
