Question about Cobra LI3900-2DXVP (14 Channels) 2-Way Radio
Stuck on rx mode
Radio seems to be stuck on RX mode. Not Sure what RX mean, but that is what displayed on the radio. Receives transmission, but can't send. Please help.... Thanks
  • Cobra Master
  • 1,654 Answers
Rx is an abbreviation for receive. (Tx is transmit) There are a variety of reasons a radio will be "stuck" in Rx:
1) Another radio in the group is stuck in transmit and you cannot reply if your radio is receiving the other radios transmission.
2) Your radio is programmed for Rx only.
3) Your radio has a Tx problem such as a bad mic, or something covering the mic opening.
4) Your battery is low or bad. It takes more energy to Tx than to Rx.
Best regards.
Posted on Feb 11, 2014
4 Suggested Answers
aloha27
  • 696 Answers
SOURCE: One of my Cobra Microtalk radios is stuck on RX.
Hi!
Almost always, the problem here is that the micro switch for the Push-to-Talk (PTT) button has failed. Your radio should have a warranty, but even if the warranty has run out, it isn't horribly spendy to fix. I'd get in touch with Cobra Electronics, I have heard they're extremely helpful. Try this link and good luck!
https://www.cobra.com/help/
Posted on Jul 06, 2011
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
cool78259
  • 228 Answers
SOURCE: one of my walkie talkie has an RX on the display
depending on what radio you have, they are programmed in different ways, rx means recieve signal
and tx means transmit signal, if you have a mode button, you will have to scroll through it until you
get to the menu that allows you to change the radio transmission. it looks like that radio is only
programmed to receive signals and not transmit. good luck!
Posted on Mar 10, 2011
Why does my new Honda CB always show RX receiving transmission no matter where squelch is set?
if this is on a Goldwing, it appears that you have a shorted pin int he connector. Disconnect the radio and make sure all of the pins are straight and connecting properly.
Oct 02, 2014 | Radio Communications
What does the "RX" mean on the display? How do
RX means that the radio is receiving a signal, this will put most of the cobra 2-ways into a locked state. many of the cobra models have an issue were after a bit of use, they will seem to receive a "mystery signal" sometimes, carefully taking the radio apart and cleaning out the inside with canned air will help, you may also check the terminals that the batteries connect too, otherwise the SoC (system on a chip microcontroller) likely has an issue.
Jul 02, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
I HAVE UNIDEN TWO WAYS HOW DO WE TAKE THE RX OFF
  • You need to get your radio out of monitor mode. To do this just pres the "mon" button for two seconds. Monitor allows you to just listen on that frequency and also receives weaker than normal transmissions while in "monitor" mode as well.
Regards, Tony
May 09, 2011 | Uniden GMR-1088 2-way Radio Walkie Talkie...
I have two uniden GMR1088-2CK radios, If I press the transmit button on the side and speak into the Mike you can see tx appear in the display, the 2nd unit receives the call, rx appears in the display and...
What this code indicate mean that your radio have have been compress with power however the can also be an indication of lower power supply but most of the time is always power compress.
What you need to do to solve this code problem is to put off the radio for some time allow it relax, then remove the battery if possible after some time replace it if you are able to remove the battery then put on the radio and operate it.
Good luck.
Jan 15, 2011 | Radio Communications
Hi, I have a LXT380/385. I find out haw to turn
I had the same issue here is the quote from the owners manual: To increase/decrease the volume level, press the up or down button during RX or STANDBY mode. With both radios on the same channel hold down the transmit or "PTT" button--this will put the other radio in the RX mode. While holding down this PTT or side button on one radio then you can adjust the volume on the other radio using the up or down arrows. (This is how you do it on RX mode. I'm not sure yet how to enter Standby mode.)
Oct 30, 2010 | Midland LXT365VP3 Two Way Radio
Radio stuck in RX mode.
Your PTT button is possibly at fault. It may be partially depressed, leaving your receiver open. Behind your PTT button there is an internal PTT button on the componet board. It may be stuck or defective.
Feb 28, 2010 | Radio Communications
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Feb 18, 2010 | Radio Communications
One of my walkie talkie has an RX on the display and you can send but you cannot hear the other person. How can I remove the RX as that seems to be the only difference in them. Thank you
Nov 11, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
GMR1035-2
The RX symbol and static noise would only appear if the squelch is down or if you are receiving something from a transmitter.
Receiving something could mean either an intelligent radio transmission from another comparable unit or this could also be spillover signals from adjacent radio transmitters strong enough to override the squelch settings normally called "splatter". At times, electronic devices could cause this effect such as RFI (radio frequency interference) from units such as a personal computer.
It is also possible that your Monitor Mode is "ON", turning it OFF would possibly resolve the issue To turn OFF monitor mode:Press the vol/mon UP or DOWN key. The RX icon will stop blinking and disappears.
In some cases, a component failure would cause this problem. Your GMR1035-2 uses an Automatic Squelch Feature, this would mean the use of a FM Discriminator Chip for Squelch Control. Most manufacturers uses an MC3357P IC chip for this purpose. This of course would require opening the unit, desoldering the suspected component and solder in a replacement. This would further require that you be familiar with electronic components, circuitry, DVM and a low wattage soldering iron. Should you not be comfortable doing this, perhaps your best bet would be to seek the services of a qualified technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 10, 2007 | Radio Communications
Cobra LI3900-2DXVP (14 Channels) 2-Way Radio Logo
3,909 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
