Question about IBM Infoprint 6700 R40 Printer
Change transfer roll infoprint 1552
Platen roller
3 Suggested Answers
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
  • 18 Answers
SOURCE: My IBM Infoprint 1552 is leaving gray spikes at
Check your toner cartridge (most print quality problems are toner cartridge problems) if that is not the problem (and it probably is) then check the fuser for toner buildup matching the defect you have. There is also a small possibility of the laser being deflected and causing this (unlikely) but clean the small mirror above the toner cartridge (it is small in height and as long as the machine is wide and up in a cavity)
Posted on Apr 05, 2010
The roller does not hold paper tight so will not roll or advance
on either end the platen roller has collars, some you can sqeeze and lift the roller out.some have release and turn type mechanism. under the platen roller there are several smaller rollers . 6 to 8. inspect this area for foreign debris. clean with 70% alcohol. reseat the platen roller and test.Platen will lock in if not its in that latch.the worst case is you have a broken gear.
Jul 24, 2015 | Brother Ml-100 Electronic Typewriter -...
917.00 transfer roll
The cuase is the HVPS card. Clean it or replace it.
Mar 30, 2012 | IBM Infoprint 1552n Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
Feb 08, 2010 | IBM Infoprint 1552 Laser Printer
I recently changed the toner cartridge on my IBM Infoprint 1552. Now I get a thin smudgy line all the way down the right side of printed materials. I know it needs to be cleaned, but I don't have a manual,...
Chances are you have a smudge on your drum roller... (its the shiny metallic tube). Roll it around and see if can see any foreign materials on it, and wipe it off carefully with a lint-free cloth.
Oct 15, 2009 | IBM Infoprint 1552 Laser Printer
Error 80-maintenance
80 Scheduled Maintenance
The operator panel displays this message at each
300K page count interval. It is necessary to replace
the fuser assembly, transfer roller, charge roll, and pick
rolls at this interval to maintain the print quality and
reliability of the printer. The parts are available as a
maintenance kit.
Description Part number
Infoprint 1332/1352 Infoprint 1372
115 V Maintenance kit 56P1409 56P1855
220 V Maintenance kit 56P1412 56P1856
100 V Maintenance kit 56P1413 56P1857
I have new Maintenance Kits in stock at this time. You have the option of doing the kit on exchange or outright. Your Part # should be 56p1409 if you are in the US.
Please give me a call for pricing of if you have any other questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
AOL IM: RORYMRP
rcardenas@mrp.to
Jul 07, 2009 | IBM Infoprint 1352 Laser Printer
Infoprint 1532 Faded txt on left half of page and normal on right
The problem is the transfer roller. If you remove the toner cartridge and look at the roller that is under it. It should be seated down. The gears should be on the left side. Try to remove it and replace it the correct way.
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
Resetting IBM infoprint 1552 maintenance counter
Apr 22, 2008 | IBM Infoprint 1552n Printer
IBM Infoprint 6700 R40 Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
