Question about Konica Minolta bizhub Office Equipment & Supplies
Clear error message
My machine is refusing to pick a 3 paper it keep on bringing error massage which says paper jam but no paper jam
  • Konica Minolta Master
  • 6,161 Answers
Clean the rollers for that draw or have them replaced
Posted on Jan 24, 2016
SOURCE: Continual Paper jam HP Officejet 6310
i have the same issue but with thicker papers only. when i use regular A4 paper no error or jam occurs...but when use thicker paper of envelope, it jams......
Posted on Jul 13, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
  • 300 Answers
SOURCE: Keep getting an error message
If you can't see any paper stuck inside the printer when you open the rear door or when you remove the toner cartridge, the rear paper flag is either stuck or broken.
The flag is a small piece of plastic which sits at the rear of the fuser and as the paper exits the fuser it pushes the flag down. The easiest way to see this is to remove the rear door then the rear cover (two screws).
If it's broken you'll require a replacement fuser (i don't think you can get the part separtely), but if you have recently installed a maintenance kit, i would contact the supplier and ask for a replacement.
Posted on Apr 20, 2009
FixinFax
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
ChineseCrap
SOURCE: HP j4680 all in one printer constant Paper jam message
Based on encouragement from olsnake above, I fixed it easily. It definitely WAS the encoder wheel (a thin clear plastic disk printed
with timing marks) on the left side of the paper-feed roller, as you look at it from the front. This wheel provides motion feedback to the paper feed control software. If the disk is detached/loose, the device thinks the paper feed roller is stuck or impeded, and thus gives the annoying error.
What I did:
1) Remove the scanner assembly (it comes off with a few screws, and is a totally separate unit; The printer works with it completely disconnected (after it complains that the scanner is malfunctioning). Beware that you don't break off the little control panel. Or you can be safe and remove the one screw holding it on, by prying off the 'HP OfficeJet...One" plastic cover.
2) Once you have removed the scanner assembly:
at the left side you will see three white plastic gears meshed together; the farthest one is covered in a circular black
plastic cover. With some care you CAN remove this cover without any additional screwdriver work.
3) in my case (and most others I bet) the thin disk was detached from the gear to which it should be attached. I just shoved it back on, so it was tightly mated to its white gear. You should also ensure that the clear disk goes through the optical sensor at the bottom (mine was).
4) I did not bother to replace that cover, if you can do it, good for you.
5) Test, and reassemble.
This is about the WORST product engineering imaginable. But I have a working printer again!
Posted on Jan 17, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
After restarting the machine shows the ready to copy massage it later bring a red indicator without any massage on the screen but the lower massages remain such as copy ratio, density among others what...
did you check jam indicator that glows red left from LCD panel?
Try to reopen the paper drawer and put it back strongly.
If you have dadf it can show jam if its lift up all the way.
On leftsideway, beneath the left door is paper pick up door reopen them and close more strongly.Also check the sensor flapper in the middle, wich is seen when paper pass door are opened.
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Sep 04, 2010 | Canon iR 2016i Black and White Copier
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
241.10 paper jam- couldn't find any paper jam. How do I clear the message?
Error Code: 241.10
Page was not properly picked from tray 1
Possible Causes
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Solutions
1. Fan media.
2. Turn media over.
3. Reduce amount of media loaded in tray 1
4. Replace pick tires.
Oct 29, 2009 | Lexmark T640 Laser Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
HP D155xi - Error Message: Clear Paper Jam (when there is none)
Have an HP office jet d155xl printer and every time I put it on, it takes sometime to warm up then the "scanner failure" pops out on LCD with instructions to put printer off and on again. Same thing happens all over again.
Oct 18, 2007 | HP OfficeJet D155xi All-In-One InkJet...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
