Question about Western Digital My Passport Essential 500GB External USB 20 Portable Red 500 GB Hard Drive
Data error cyclic redundancy
It's not showing the partition when try to open with my computer but you can see this partition in manage but it has failed to format
  • 4 Answers
Hi
There are several situations that might have caused a damaged to the driver.
DATA ERROR CYCLIC REDUNDANCY might have been caused by a Virus attack. And in those cases, you will provably end up buying a new hard drive.
How would I know that? Well, just check your memory and remember if you had been doing some Internet search/chat/downloading some stuff/visiting unknown sites, etc., prior to the damage.
It ussually happens when you are using Chat programs, in which you may have received a file or a link to visit to
(most likely the virus made an unrecoverable damage on the main section of the drive, the MBR - Master Boot Record)
Posted on Sep 02, 2014
5 Suggested Answers
Vish2
  • 74 Answers
SOURCE: Partition error
Try using the command FDISK /mbr. This should fix the master boot record. If not, then if you don't care about the data on your drive, you could wipe it clean with any of the several utilities available on the web and then try partitioning it. Search for "Wipe Disk" in Google.
Posted on Sep 28, 2007
Ezrahite
  • 2632 Answers
SOURCE: i am getting the data error (cyclic redundancy
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Posted on Jan 31, 2011
    axn_almighty
    • 267 Answers
    SOURCE: How to repair and recover WD5000AAKS hard drive
    The problem may be there in your hard drive, try the hard drive with another computer and if the problem persists, go to the nearest Service Center of the Manufacturer.
    If the problem is solved on another computer, try repairing your OS first.
    Hope this helps, Mrityunjay.
    Posted on Jun 21, 2012
    bronk50
    • 27725 Answers
    SOURCE: i can't access wd 320gb element external hard drive
    click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
    right click to reinstall drivers or
    if you can see your usb but its not working
    ports(com&lpt)right click update driver
    even if you dont have any red or yellow marks you might have to
    Click Start, then type device manager in the Search box then click Device Manager
    Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
    Once complete restart your computer. Your USB controllers will automatically install
    This method prevents your USB external drive from powering down
    Disable USB selective suspend setting.
    This method prevents your USB external drive from powering down.
    Click the Start button type power plan in the Search box then click Choose a power plan.
    Next to your currently selected plan click Change Plan Settings.
    Click Change advanced power settings.
    Click the box to expand USB Settings then expand USB selective suspend settings.
    Click Plugged in then click the drop down menu and select disabled.
    If youre using a laptop click Battery then click the drop down menu and select disabled.
    Click Apply then click OK.
    if this fails to fix the problem
    check usb leads for secure dust free seating
    sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
    just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
    check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
    hope this helps
    Posted on Jun 28, 2012
    Data error. Cyclic redundancy check
    https://www.openfiletool.com/pstopen.html
    This application protects the privacy of user information and does not forward your personal data to some kind of external services for PST file analysis.
    Regards
    Oct 28, 2017 | The Computers & Internet
    Data error cyclic redundancy check
    This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
    Dec 29, 2013 | Transcend Computers & Internet
    How can I fix Cyclic Redundancy Check on external drive?
    This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
    Feb 20, 2013 | Computers & Internet
    500 MB data error(cyclic redundancy check) external hard drive is not accessible
    1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
    2. This issue could be due to the data controller on the USB drive being defective.
    3. try purchasing a new case with a new controller board.
    4. Check to see if your 1TB USB drive is compatible with your pc.
    Jun 13, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
    The Samsung Freeagent GoFlex external hard drive is not recognized by Windows 7 OS. I tried to initialize disk under computer management / storage / disk management and got the cyclic redundancy check...
    This is a good read on what this error actually means:
    http://www.softwarepatch.com/tips/cyclic-redundancy.html
    What I recommend is reformatting the drive under Computer Management, and seeing if that fixes the problem.
    May 03, 2011 | Seagate FreeAgent GoFlex Pro 500 GB USB 20...
    When i install,bluetooth setup in my desktop that time a information came like cyclic redundancy check problem.
    Cyclic Redundancy Error comes when the source device like a computer calculates data and add the size of the information and sends it to the destination device. The destination device sees the size of the information and recalculate the size of the information and compare the two if they do not match the cyclic redundancy problem is reported because the information data has gone corrupt during the transit from the source to destination device. It can be a wrong configuration or packet collision. If it is due to packet collision the error can be over come by resending data multiple times.
    Sep 11, 2010 | Computers & Internet
    When I try to copy Outlook data from the DVD to HDD it is getting an error '' cannot copy Outlook: data error (cyclic redundancy check) kindly do the needful to resolve the issue. Thanks & Regards...
    CRC error indicates bad sectors, try one thing:
    open the data file from outlook and from there create a new pst on the destination and copy the mails, you may loose some mails but the rest of the data will be safe
    Jul 23, 2009 | Computers & Internet
    Data error cyclic redundancy check. I have windows XP.How do I fix this?
    Your disc is scratched. That error will come up when it happens. Try to clean your disc. get all the fingerprints off of it.
    May 24, 2009 | E-Machines eMachines Desktop PC
    Unable to copy files from cd
    Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
    Thanks
    Mar 01, 2009 | Computers & Internet
    Open Questions:
    Western Digital My Passport Essential 500GB External USB 20 Portable  Red 500 GB Hard Drive Logo
    176 people viewed this question
    Top Western Digital Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
