Commitment DEL/INT TO DEL EXCEP HAZ DRUG - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 26,693 Answers
No idea what you mean.
Posted on Feb 07, 2014
How do I forward my phone number on a Dect 6.0 cordless phone model 30524
Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
I hope this helps.
Jun 27, 2018 | Dect Lands Phones
Parking lights stuck on
the park lamp relay is stuck on. its bad or the control to it is bad.
hazards next.
ok HAZ does glow park to park is a red herring.
the HAZ relay is stuck on, or controls to it are bad
the BCM 100% controls hazard at all times
the BCM gets and input from you , that you want HAZ and then closes the relay/
the HAZ switch ground pin 18 on the BCM, it not 12v here the switch is bad.
IF NOT< bad switch input the HAZ relay is bad.
Dash Fuse Box , fuse 7 is haz. and the relay is there.
replace the relay or the switch,
if you unplug the relay the haz will die.
i bench test relays and am not , doing that here.
Jun 24, 2014 | 2003 Hyundai Tiburon
Source code for implementation of linked list using opengl in vc++
Source code:
#include
using namespace std;
class linklist
private:
struct node
int data;
node *link;
}*p;
public:
linklist();
void append( int num );
void add_as_first( int num );
void addafter( int c, int num );
void del( int num );
void display();
int count();
~linklist();
linklist::linklist()
p=NULL;
void linklist::append(int num)
node *q,*t;
if( p == NULL )
p = new node;
p->data = num;
p->link = NULL;
else
q = p;
while( q->link != NULL )
q = q->link;
t = new node;
t->data = num;
t->link = NULL;
q->link = t;
void linklist::add_as_first(int num)
node *q;
q = new node;
q->data = num;
q->link = p;
p = q;
void linklist::addafter( int c, int num)
node *q,*t;
int i;
for(i=0,q=p;i {
q = q->link;
if( q == NULL )
cout return;
t = new node;
t->data = num;
t->link = q->link;
q->link = t;
void linklist::del( int num )
node *q,*r;
q = p;
if( q->data == num )
p = q->link;
delete q;
return;
r = q;
while( q!=NULL )
r->link = q->link;
delete q;
return;
r = q;
q = q->link;
cout}
void linklist::display()
node *q;
cout for( q = p ; q != NULL ; q = q->link )
coutdata;
int linklist::count()
node *q;
int c=0;
for( q=p ; q != NULL ; q = q->link )
c++;
return c;
linklist::~linklist()
node *q;
if( p == NULL )
return;
while( p != NULL )
q = p->link;
delete p;
p = q;
int main()
linklist ll;
cout ll.append(12);
ll.append(13);
ll.append(23);
ll.append(43);
ll.append(44);
ll.append(50);
ll.add_as_first(2);
ll.add_as_first(1);
ll.addafter(3,333);
ll.addafter(6,666);
ll.display();
cout ll.del(333);
ll.del(12);
ll.del(98);
cout return 0;
May 19, 2011 | Computers & Internet
Necesito instalar la impresora pero la comutadora no reconose el programa
Hola:
Tu puedes bajar el software directamente del internet, solo tienes que ir al sitio de la marca de tu impresora, por ejemplo si es una HP ve a: www.welcome.hp.com. Y haz click en support and drivers y escoje el modelo de la impresora que compraste. Es todo.
Mar 07, 2011 | HP Computers & Internet
Quise instalar activex y resulto que internet explorer entro en conflicto
Resuelve siguiendo estos procedimeintos:
Puedes optimizar internet explorer mediante el seguimiento de los siguientes m?todos: M?todo 1: Borrar datos almacenados en cach? en Internet Explorer Para determinar si es un problema de rendimiento o un mensaje de error motivado por los da?os en los archivos temporales de Internet o en otros en cach? informaci?n que se utiliza Internet Explorer, debes borrar los datos almacenados en cach?. Para Para ello, sigue estos pasos: 1. Abre Internet Explorer 7. 2. Haz clic en Herramientas y, a continuaci?n, haz clic enEliminar Historial de exploraci?n. 3. En Eliminar historial de exploraci?n, haz clic en Eliminar todos. 4. Haz clic para seleccionar el Eliminar tambi?n los archivos y configuraciones almacenados por los complementos la casilla de verificaci?n y, a continuaci?n, haz clic en ACEPTAR. Si sigue produci?ndose problemas, prueba el m?todo 2. M?todo 2: Restablecer la configuraci?n de seguridad para Internet Explorer Si establece la configuraci?n de seguridad demasiado restrictiva, puede impedir que Internet Explorer muestre ciertos sitios Web. Para determinar Si un problema es causado por la configuraci?n de seguridad demasiado restrictiva, vuelve a la configuraci?n de seguridad predeterminada. Para ello, sigue estos pasos: 1. Abre el Explorador de Internet. 2. Haz clic en Herramientas y, a continuaci?n, haz clic enOpciones de Internet. 3. Haz clic en Seguridad . 4. Haz clic en Restablecer todas las zonas al nivel predeterminado, y, a continuaci?n, haz clic enACEPTAR. Despu?s de hacer esto, prueba Internet Explorer para comprobar si funciona correctamente. Si contin?a produci?ndose problemas, intenta con elm?todo 3. M?todo 3: Ejecutar Internet Explorer en modo "Sin complementos" Complementos de Internet Explorer, como controles de ActiveX son utilizados por algunos sitios Web que utilizan las barras de herramientas, para proporcionar una exploraci?n mejorada experiencia. Puede producirse un error si un complemento se da?a o si un complemento entra en conflicto con Internet Explorer. Para determinar si el error se produce por un complemento, que ejecute Internet Explorer intenta abrirlo en modo "Sin complementos".
Para ello, sigue estos pasos: 1. Haz clic en Inicio y, a continuaci?n, escriba Internet Explorer En el cuadro de di?logo Propiedades de Iniciar b?squeda cuadro. 2. Haz clic en Internet Explorer (sin complementos). Internet Explorer se abre sin complementos, barras de herramientas o plug-ins. 3. Prueba Internet Explorer para comprobar que funciona correctamente.
Si contin?a produci?ndose problemas, intenta con el m?todo 4. Si no se producen errores, el problema est? causado por uno de los complementos que normalmente se cargan junto con Internet Explorer. En este caso, utiliza uno de las siguientes opciones. Opci?n 1: Restablecer Internet Explorer Restablece la configuraci?n predeterminada de Internet Explorer. Este paso tambi?n deshabilitar? los complementos, plug-ins y barras de herramientas que est?n instalados. Aunque esta soluci?n es r?pida, tambi?n significa que, si desea utilizar cualquiera de los complementos en el futuro, debe ser reinstalados. Para restablecer la configuraci?n de Internet Explorer, usa el m?todo 4. Opci?n 2: Usar el administrar complementos herramienta para determinar qu? complemento est? causando el problema Utiliza la herramienta Administrar complementos en Internet Explorer para deshabilitar individualmente cada complemento para determinar qu? complemento est? produciendo errores. Para ello, sigue estos pasos: 1. Abre Internet Explorer 7. 2. Haz clic en Herramientas, seleccione Administrar Complementosy, a continuaci?n, haz clic enHabilitar o deshabilitar complementos. 3. En el cuadro Mostrar , selecciona Complementos que han sido utilizados por Internet Explorerpara mostrar todos los complementos que se instalan en el equipo. 4. Para cada elemento de esta lista, selecciona el complemento y, a continuaci?n Haz clic enDeshabilitar en el men? de configuraci?n. 5. Una vez desactivados todos los elementos de esta lista, haz clic en ACEPTAR. 6. Salir y reiniciar Internet Explorer 7. 7. Si no se producen problemas, repita los pasos 1 a 3. 8. Haz clic en Habilitar para un ?nico complemento. 9. Repite los pasos 6 a 8 hasta que averig?es qu? complemento hace que se producen errores. M?todo 4: Restablecer la configuraci?n de Internet Explorer Para determinar si es un problema de rendimiento o un mensaje de error causada por los valores de configuraci?n, restablece la configuaci?n de Internet Explorer a su valor predeterminado. Utiliza esta herramienta para realizarlo autom?ticamente C?mo optimizar Internet Explorer: http://support.microsoft.com/kb/936213/es Si deseas realizarlo manualmente sigue estos pasos: 1. Abre el Explorador de Internet. 2. Haz clic en Herramientas y, a continuaci?n, haz clic enOpciones de Internet. 3. Haz clic en la ficha Avanzada . 4. Bajo Restablecer la configuraci?n de Internet Explorer, Haz clic enRestablecer. Restablecer la configuraci?n de Internet Explorer 7
(http://windowshelp.microsoft.com/Windows/es-es/Help/81fe3b46-2460-459e-b826-8f134a7fe1771033.mspx) M?todo 5: Solucionadores de problemas Internet Explorer en Windows 7 De forma predeterminada, Windows 7 tiene los siguientes solucionadores de problemas de Internet Explorer dos: 1. Rendimiento de Internet Explorer 2. Seguridad de Internet Explorer Ejecuci?n de los solucionadores de problemas de Internet Explorer 1. Cierra todos los programas. Haz clic en Inicio , y luego en Panel de control. 2. Haz clic en Buscar y solucionar problemas bajo Sistema y seguridad. 3. Haz clic en Ver todos en el panel de tareas de la izquierda. 4. Haz clic en Rendimiento de Internet Explorer. 5. Haz clic en siguiente en el cuadro de di?logo. 6. El Solucionador de problemas ejecutar? y corrige autom?ticamente todos los problemas identificados. Haz clic enCerrar.
Dec 04, 2010 | Internet Allume Systems Cleanup 1.0 Full...
El mouse de mi laptop no funciona ke hago
Dependiendo de tu sistema operativo:
1-Ve a Control Panel
2-Localiza "Muose" o hardware
3-Haz click en el y luego ve a hardware.
4-Si no esta
6-ve a MY Computer y haz un Right Click
7-selecciona Manage
8-luego Device manager y ve si en algun lugar ves un simbolo amarillo;si esta en amarillo haz right click en el y selecciona Update driver.
Si nada de esto funciona ve otra vez al 8 y haz right click y seleciona unistall.Apaga el PC y prendelo otra vez.Se supone que el sistema(OS) lo localize y lo instale automaticamente.
Si no fuciona esto entonces ve a Control PAnel i desintala el driver en ADD or Remove Programs.Usa el CD del mouse e instalalo otra vez.
Escribe luego a ver que pasa,Miguel.
Dec 01, 2010 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Trans slips excep in 4x4
Transfer case could be bad or linkage out of addjustment.
Aug 03, 2009 | 1999 Dodge Ram
No tengo el cd y quiero intalar una camara logitech 961306
hola raul....
tienes que ir al web de logitech a esta página para elegir tu país.
una vez que has entrado en el web... haz un clic en el enlace para 'Asistencia' (arriba del todo en letra muy pequeñita). en la parte 'Buscar por nombre' elija cameras web... y debajo el modelo, y haz un clic en la flecha.
en la página siguiente, haz un clic en descargas y después en tu sistema operativa y después en el archivo....
Muy Importante:
para elegir el archivo necesitas saber si tu sistem operativa es de 32 o 64 bits... lo puedes averiguar haciendo un clic derecho en el icono de 'Mi Pc' (en XP) o 'Equipo' (en Vista) y seleccionando propiedades del menú emergente.
espero que esto te sirve de ayuda, y avisame si tienes alguna pregunta mas!
bru*
Feb 17, 2009 | Logitech QuickCam Messenger Web Camera
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
