Question about ECS Computers & Internet
Ecs g41t-r3 wont power up but when i reset the cmos, it's power up and run smoothly, but when i shut it down, it never power up, again i need to reset the cmos to power it up..pls help
alxz
  • 89 Answers
SOURCE: Toshiba Satellite A105-S2001 System
Change your power supply unit, it is definitely defective. You may open the Psupply case and you should be able to see come blown components, like capacitors.
Posted on Jun 04, 2008
  • 51 Answers
SOURCE: I have a motherboard ecs pt890t-a
To save yor changes you need to hit f10. If you are trying to flash your bios you need to make sure the bios protect jumper is in the correct postion.
Posted on Jun 08, 2009
  • 50 Answers
SOURCE: My ECS P4M800Pro-M board will not hold bios after shut-down.
Yeah that should help!!
you can download the latest updated bios from the below mentioned link
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=574&CategoryID=1&DetailName=Bios&MenuID=52&LanID=0
Pharthiphan
Posted on Nov 06, 2009
CreativeTECH
  • 1719 Answers
SOURCE: cmos problem: always reset cmos everytime
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Just open the desktop, locate the CMOS (Coincell) and remove using screw driver. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Posted on Feb 21, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: how i do for unlock
Hello
Switch to manual in the bios memory selection.
Posted on Jun 26, 2011
I need user manual for g41t-am motherboard
Try here
http://download.ecsusa.com/dlfileecs/manual/mb/p4/G41T-M7/G41T-M7_V10B_manual.PDF
Aug 29, 2014 | ECS Computers & Internet
When I start PC, nothing display
Hello Sam, make sure you are using a good RAM module. check your RAM with other PC prior to your PC.
Jan 03, 2014 | EliteGroup ECS G41T-R3(V1.0A) LGA 775...
Ecs 945g m3 motherboard manual
IF the computer starts up, runs smoothly for up to 5 minutes, then shuts down, it might be a heat problem. Firstly disconnect all fans, then using a blower, blow out all the dust inside the computer. switch on and test. Reply if problem is solved or not.
Dec 28, 2013 | ECS 945G-M3 (V3.0) Motherboard
I need sound driver for g41tm motherboard
ECS G41T-M v2.0 motherboard supports Intel Core 2 Quad processors, and supports FSB up to 1333MHz
G41T-M features Intel G41 and ICH7 chipsets, by supporting Intel 45nm processors and Core 2 Quad processors, which provides impressive performance. Additionally, G41T-M is equipped 2 DIMM DDR2 800 up to 8GB
get sound (and more) drivers here :
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=925&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
Jan 10, 2013 | EliteGroup G41T-M6 Motherboard
Jun 04, 2008 | Asrock K7S41GX Motherboard
Computer shuts down but does not turn off
Mchem, you actually have 2 separate issues going on there.
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
  • click ok
  • click ok
  • Open control panel > open power options
  • in the power options properties, select the advanced tab,
  • in the power buttons section,
  • When I press the power button on my computer: click on the drop down menu and select the shut down option
  • click ok
Sebastien123, you only need to run the first part of this solution.
Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
Computers & Internet Logo
Top ECS Computers & Internet Experts
David
David
WTF Chuck.....
WTF Chuck.....
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
