Question about APC American Power Conversion InRow RD Air Cooling Solution – 42U (ACRD100)
APC INROW DX ACRP102 air conditioner does not cool and showing "compressor drive fault" alarm
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
What is a vsp fault 10 alarm Ingersoll rand
A VSD 10 fault is bus oscillation. Quickly rising and falling voltage. Recommend having power company check incoming voltage for oscillation.Voltage can not vary more than 3 percent or alarm is issued.
Mar 09, 2011 | Ingersoll Air Tools & Compressors
I have a highlander portable air conditioner..it does'nt run probaly on cool nor doe's it drain water..it keeps switching off showing message on screen E4 fault..please advise..did not recieve manual in...
E-4 Abnormality of out door unit or overload in compressor. Check condenser coil, if dusty clean it. F.motor struck, replace it.
Running amps gradually increasing means weak capacitor. Replace capacitor.
Thanks.Hope helpful?
Jan 22, 2011 | Heating & Cooling
Compressor starts then stops after maybe 3 mins
Any error codes? If not there may be a mechanical fault with the compressor/inverter. The unit is possibly short on refrigerant, so the compressor is not getting enough suction cooling from return gas, so may be clicking off on its internal over temp klixon.
all the best
Jul 05, 2010 | Mitsubishi MS-A09WA Split System Air...
LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
May 04, 2010 | LG Art Cool LA181CNW Split System Air...
I have a Jetta 99 GLS w/197K. I took the car to the mechanic and they said it was the compressor. Repairs are approx 1K. My question is, can the car be driven as is? I do not know what is the corrleation...
I presume the compressor you refer to is the air conditioner compressor.
If so, the car can be usually be driven as normal so long as you don't operate the air conditioner cooling. With the air conditioner off, the compressor is not in use.
If the fault with the a/c compressor is with the front bearing (drive noise or belt squeal) you may need to remove the drive belt.
Oct 26, 2009 | 1999 Volkswagen Jetta
Dometic RV air condtioner will not cool
Replace the compressor run capacitor.
Jul 05, 2009 | APC Heating & Cooling
Error Code on LG Art Cool
error code CH22 is either compressor or inverter fault.
Jun 01, 2009 | LG Art Cool LA091HNP Split System Air...
I bought a haier electronic control air conditioner model HWR10XC6 on 6/30/08. I installed it. When I try to use the cool mode the air conditioner will only blow out cold air for about 5 - 10 minutes and...
It sounds as if the compressor (that provides the cooling) is cutting out due to either a faulty thermostat or is itself overheating.
Obviously check the thermostat is able to move between it's minimum and maximum levels, anthat this corresponds to the compressor cutting in and out.
With maximum cooling selected, the compressor should not cut out untill the thermostat says it's cool enough. If it does, there is a fault, and you have every right to a refund or a free repair/ replacement.
The fault is usually centered around the compressor electrical components if it is not under any warranty, but it should be. Even if the store does not want to know, the manufacturer should back it for 1 year.
Thanks for using Fixya!
If you need to attempt repair - ask again.
Jul 06, 2008 | Haier Heating & Cooling
APC American Power Conversion InRow RD Air Cooling Solution – 42U (ACRD100) Logo
64 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
