Question about NComputing Computers & Internet
Healthrider treadmill error code 22 - NComputing Computers & Internet
4 Suggested Answers
bwinton
  • 83 Answers
SOURCE: Belt slipping on treadmill
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
dj_relly999
  • 4070 Answers
SOURCE: healthrider treadmill modle #HTRL21470 serial
Hi and welcome to FixYa!
An E2 is definitely a system failure. As a first course of action I strongly suggest that you press the reset button on the frame near the power cord. This will reset the system and can get the treadmill back to it's normal operation.
If the problem still persist please unplug the unit from power source and switch the treadmill ON while unplugged to hard reset the system.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jan 17, 2011
Soft strider by healthrider tread mill does not function and the error code PO comes up any suggestions?
1) Please exchange batterires for a new ones.
2) Tight the flexible cables from keypane vs display board.
3)Tight the connector from display board vs lower board(Main motor board)
4)Adjust the reed sensor switch by 1/8" or 3mmsSee the diagram attached.
5)Measure input voltage for 115 Vac to input of main motor board
6) Measure input for power supply for +5VDC to main motor board.
7)Measure output voltage for +5vdc to Display board.
8) Finally see the block diagram that I am attached that I did for people like you. For easy diagnostic and troubleshooting.
Sincerely. Merry Christmas.
Ernesto CuaddraManagua, Nicaragua.12_24_2011_4_58_14_pm.gif12_24_2011_4_58_29_pm.gif
Dec 23, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
Treadmill not working. Troubleshooting: Receiving E21 message. What does E21 indicate?
The E21 error code indicates that the console is not receiving a signal from the sensor that controls the speed on the treadmill. This means there could be a problem with the speed sensor. You may need to have a technician check the voltages on the power board and controller.
Nov 27, 2010 | HEALTHRIDER Exercise & Fitness
Computers & Internet Logo
65 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
