Question about Carnation CR2323 UV/IR/MG Banknote Counter-
What is the Nu-Tec 5.1 Channel DVD Player, - Carnation CR2323 UV/IR/MG Banknote Counter-
How do I get an instruction manual for a Nu Tec model NUE1958?
Try this site: http://www.nu-tech-dsp.com/content.php?id=4&sid=5
Mar 07, 2015 | Televison & Video
Bw7080 remote to a nu-tec tv & dvd comb
Just buy one universal remote control, which have setup codes for your brand combo. You can get this detail by the code list accompanied with the remote control. Brand isn't matter.
Apr 30, 2012 | Televison & Video
Need code/tv-nu tec/universal one for all
Universal One-For-All Remotes actually have a website that you can get the codes from! I have this same remote & just googled it.
Feb 29, 2012 | Televison & Video
Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital antener. all works but I can't get any channel 9 stations no matter how many times I rescan channels?
''Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital ''
Poor English!
It should read; ''Bought a Coles $259 Nu-tec DVD/Tv combo, brought it home and set it up with a indoor digital ......''
Jun 12, 2010 | Televison & Video
I bought a NU-TEC DVD 318 I want to make it region free
1. Turn on the DVD player, and DO NOT have a disc in the unit.
2. Press the “setup” button on the remote, and then press "1389" on the remote.
3. You will then see an information screen, with Region Code: 4 displayed.
4. Use the Up and Down keys on your remote to change the Region Code to 0, and then press the Enter key on your remote to confirm the change.
5. Press the Setup button to exit the setting.
Your unit should now be region free.
Mar 19, 2010 | Televison & Video
Nu-Tec TV/DVD Combo
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sep 03, 2017 | Televison & Video
Nu-tec NTV2131 51cm TV
Press the 'display' button for 5 seconds
Mar 31, 2008 | Hotpoint RVM1625 Microwave Oven
Amstrad Widescreen TV
Hi.
Have you got the remote control for the tv set ?
You must put tv on AV channel you can only do this using the remote.
Allso double check that the yellow phono plug is in the socket marked video in on tv set.
Let me jnow how you get on.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Carnation CR2323 UV/IR/MG Banknote Counter- Logo
67 people viewed this question
Top Carnation Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Carnation Retail Supply Expert? Answer questions, earn points and help others
